H323 Inbound Calling Name Display
balitewiczp
Level 2
Level 2
Recently converted GW from MGCP to H323. Inbound CNAM is no longer displaying. Is there a config option in the dial-peer? Thanks
paolo bevilacqua
Try
voice service voip
qsig decode
Thanks for the response. Dont see that option. IOS 12.3(11)T8
allow-connections
cause-code
default
exit
fax
h323
modem
no
redirect
shutdown
signaling
sip
supplementary-service
testeven
Hi!
Please refer to:
--> H.323 Name Display
http://www.cisco.com/en/US/docs/ios/12_4/12_4x/release/notes/rn2800xw.html#wp363697
And check that on the H.323 GW configuration page on the CUCM admin the "Display IE Delivery on GW" checkbox.
HTH!
Teresa.
If it helps, please rate.
Regards, Tere. If you find this post helpful, please rate! :)
This helps alot. Looks like I need to upgrade to 12.4. Currently, its on 12.3
Thanks again, for the response
