H323 Issue - Help
Hi guys
I get the following debug messages while trying to make calls from one of th gateway can anybody help??
Jul 20 03:44:36.405: h323chan_chn_process_read_socket: fd=0 of type LISTENING ha
s data
Jul 20 03:44:36.405: Changing to new event: ACCEPT
h323chan_chn_accept: fd=0
Jul 20 03:44:36.405: h323chan_gw_accept: TCP connection accepted from 10.XX.XX.12
:55770 on fd=2
Jul 20 03:44:36.405: h323chan_chn_accept: Local(0x0) accepts TCP conn from 10.21
.4.12(0xA15040C) port (55770); fd=2changing from LISTENING state to ACCEPTED sta
te
Jul 20 03:44:36.409: h323chan_chn_process_read_socket: fd=2 of type ACCEPTED has
data
Hex representation of the SETUP TPKT received: 080200160504038090A26C06008135353
436700C8039303530373432303738357E007B0520B0060008914A000201400E004D002E002000410
06200640075006C002000520061007A007A006100710200010500C383A753AB80002EC1FE1274E11
D1600FF020A15076A00450C07000A15040C06B81100002EC1FE1274E11D1600FF020A15076A01000
1000AA001000F0140B50000120880C4000400010100
h225ParseData: Q.931 SETUP received on fd=2
Jul 20 03:44:36.417: h323chan_init_listen_socket: Listen fd=3 setup successful
Jul 20 03:44:36.417: compose_TunnelledSignallingMessage_ciscoNo tunnelled conten
t.
Hex representation of the CALL PROCEEDING TPKT to send.:
XXXXXXXX#08028016027E00390521C0060008914A00042800B500001240013C050100000A15
1BFDF280110C1100002EC1FE1274E11D1600FF020A15076A0100010010800100
h225CallProcRequest: Q.931 CALL PROCEEDING sent fromfd=2.
XXXXXXXX#
Jul 20 03:44:46.489: compose_TunnelledSignallingMessage_ciscoNo tunnelled conten
t.
Hex representation of the RELEASE COMPLETE TPKT to send.: 080280165A080280A27E00
22052580060008914A000411001100002EC1FE1274E11D1600FF020A15076A10800100
h225TerminateRequest: Q.931 RELEASE COMPLETE sent from fd=2. Call state changed
to [Null].
Jul 20 03:44:46.493: h323chan_chn_process_read_socket: fd=2 of type ACCEPTED has
data
Jul 20 03:44:46.493: h323chan_recvdata: Connection lost fd=2h323chan_chn_close:
Calls[1] Exist on socketfd=2 Owner[2]
Jul 20 03:44:46.493: h323chan_close: TCP connection from fd=2 closed
Jul 20 03:44:46.493: h323chan_close: TCP connection from fd=3 closed
Re: H323 Issue - Help
Call Flow is this -
Jul 20 03:44:36.409: h323chan_chn_process_read_socket: fd=2 of type ACCEPTED has data
*** You recieve a SETUP message
Jul 20 03:44:36.417: compose_TunnelledSignallingMessage_ciscoNo tunnelled content.
**** You send Call Proceeding
Jul 20 03:44:46.489: compose_TunnelledSignallingMessage_ciscoNo tunnelled content.
**** 10 seconds later you send Release Complete. You never sent Alerting, so the T310 timer expired between the proceeding and alerting call states. Most likely cause is a problem with the subsequent POTS leg of the call, or if this is IP2IP gateway, the second IP call leg.
thanks for trying to help..
issue was with Route pattern...strange but ppl at one site were able to call through route pattern X with css Y.....ppl at othe site were not using the same RP and css Y....deleted the rp and re-creted the same....everything works fne now
805
