h323 log
help me pls analyze the log. I cant perform call from 1991(Avaya phone) to 1225(Cisco 6921 SIP phone). When i call from cisco to avaya everything is ok.
CME 9.5. Avaya and Cisco connected over H.323.
P.S. Or did i need to use SIP trunk - "SIP endpoints are not supported on H.323 trunks. SIP endpoints are supported on SIP trunks only."
Thanks in advance
Re: h323 log
Can you please let me know the call flow/ topology and please confirm calling and called party number
please confirm what all debugs you have collected ?
Br, Nadeem Please rate all useful post.
Re: h323 log
also please post router config.
Br,
Nadeem
Re: h323 log
gave a quick look on the logs  I saw Cause code 47 which is "No Resources" It can usually be traced to either a lack of DSP resources, channels, or more often than not a codec issue in terms media negotiation is getting failed..
Reason cause code
Call Entry(Disconnect Cause=47,:
as you said "Call from Cisco to Avaya works fine however you make a call from Avaya to Cisco it Fails".
1) Can you please check what codec is being for working call?
2) please post the route config.
Br,
Nadeem
131
