Silver
h323 names between CUCM
I`ve set up a H323 GW CUCMA going to the Nortel and get names in both directions .I repoint the session target in the Voip Dial-peer to another CUCM 6  CUCM B
Calling from CUCM A to CUCM B, the display on CUCM A phone shows the ringing phone, Phone B shows the orginating name- on connecition names still show
CUCM B calls CUCM A, the user at B does not see any names only DN but CUCM A the user A can see CUCM B details
CUCM B GW settings
voice service pots
voice service voip
qsig decode
fax protocol cisco
h323
  h225 timeout t302 4
  h225 timeout ntf 1000
h225 display-ie ccm-compatible
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn protocol-emulate network
isdn incoming-voice voice
isdn supp-service name calling profile Network-Extension operation-value-tag local
no cdp enable
I can see the name being sent using  in Q931
CUCM-A>>>>>CUCM GWH323>>Q SIG >>>GWH323-A>>>>CLOUD >>>>>>>>GWH323-B>>>QSIG >>>CUCM GWH323>>>>CUCM-B
If I point the voip dial-Peer in  GWH323-A to another GWH323 C which connects to an TDM system then names are good in both directions. I done testing between CUCM and Nortel and Siemens and names are good but between CUCM failing.
i`m running c2800nm-ipvoicek9-mz.124-24.T3.bin
Any ideas, what debugs can I run to check  where the names drop
I`ve attached some debugs
Final Router is ay CUCM B - when CUCM A calls CUCM B
Calling CUCM B to cucm  A- you see the name SMITH being sent to GWH323-A but do not see it futher on
FInal router at CUCM B- last router at CUCM B when CUCM A calls - yo usee the name Pompeo- all ok
The configuration on the GWH323 A, B are the same , we only can change the CUCM H323 GW`s
I`ve enabled  IE display at CUCM B CUCM page
What  is the best debug to check names- I was running DEBUG 225 EVENT, Q931- the presentation is set for allowed, since if I call the TDM at GWH323-C i can see names when CUCM B calls .
Are there any commends I`ve missing?
thanks
188
