Community Member
h323 OB pots dial peer selection
H323 with multiple PRI's. Multiple tenants are sharing GW. Need to configure outbound pots dial peer so that correct one is matched based on tenant. Would this be answer address? Thanks
Hall of Fame Super Gold
Re: h323 OB pots dial peer selection
Yes. Do you have the classical link examples already ?
Community Member
No, I do not. Is there a link I can reference? thanks
Community Member
Thanks for your input, but I'm still missing something. Only concerned with outbound calling, and I have a PRI, so i dont care which channel it uses. I can see where the doc suggests to use translation patterns to append a fake digit, and then use that as the destination-pattern. I also match on destination for LD and Intl calls. (91, and 9011). How do I combine both? Sorry for the legnth explanation.
A couple of options:
Match an incoming dial peer on answer address and apply an incoming translation pattern to prepend an access code for that caller id. Then on the pots destination pattern explicitly state the access code, and since it's a pots dial peer it will be stripped.
The more complicated option is to use corlists. Match the incoming dial peer with answer address against the caller ID, apply an incoming cor list, and then have the dial peer with an appropriate outgoing corlist.
Alternatively, and with less scalability, you can have each of your customers send you a different access code from their systems, and it's much easier for you.
-nick
Silver
You could create a translation pattern for each tenant so that calls from tenant A are sent to a TP which inserts 1 infront of the dial number, Tenant B adds 2, Tenant C adds a 3 and so on. In the H323 create a dial-peer based upon each TP 19011, 29011, 39011 etc and assign that to each PRI???
If you have a call logging system be aware of the translations as now the 1,2,3 will appear in the CDR output another way is add the 1,2,3 in a Route Group that way they will not a appear
In either case you need to create a partition for each tenant so to force them to use the TP for them or Route List, Group
hope it helps
Community Member
Thanks. I'm understand everything you mentioned, I'll be matching the outbound pots dial peer with the corresponding TP. What I am having trouble with is understanding if I have to modify the route patterns. They are already divided by DP, partition, CSS,RL, etc.
Community Member
I got it figured out. Once I reread the document, and figured out I had my TP in the wrong direction (outgoing vs incoming), things are working . Thanks all for your help
Very good, please remember to rate useful posts with the scrollbox below.
Community Member
One thing I cant think through, is why I dont have to change any route patterns. I know I am not physically changing the dialed number dialed from the phone, but through the TP, I am. Thanks
Because with h.323 the router can have "intelligence" and whatever setting you have on the CCM doesn't matter.
Thanks for the nice rating and good luck.
170
