H323 PRI Gateway User/Network config
I am configuring an H323 PRI gateway in CCM, which connects to a third party's PBX. I would like to designate the CCM gateway as the "Network" side of the PRI, and the other vendors PBX as "User".
How can I specify the Network function on the CCM side?
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: H323 PRI Gateway User/Network config
controller e1 x/y
clock source internal
interface serial x/y:23 (or 15 for e1)
isdn protocol-emulate network
and check correct cabling (crossed T1/e1 per card pinout). Do not use ethernet patch or crossed!
That's it.
controller e1 x/y
That's it.
Thanks for the nice rating and good luck!
If any problem with calls, remember to include output of "term mon" and "debug isdn q931".
128
