H323 Redundant Call Path
Hi;
I am over looking something fundamental in regard to creating a redundant dial-peer. I have 2 H323 PRI gateways that are working fine. However I need to be abe to route calls between them if the H323 path in the other fails. This is needed to prevent calls from failing as I have one DID range over the 4 PRI circuits with calls being delivered cyclically across them.
I created a H323 peer on both routers and the call passes from one to the other (this is where it starts to go wrong). When the call is received it matches the new incoming H323 peer on the DNIS 12[3-4]. (test range i have). I would then expect it to match the outbound H323 peer as that peer has a destination-pattern of 12[3-4].
But instead it matches the outbound PRI peer that has an incoming called-number of . and a destination-pattern of .T
Can anyone clarify why this is???
The peers in question are below:
dial-peer voice 301 voip
description incoming from site A
no modem passthrough
incoming called-number 12[3-4].
voice-class h323 1
dtmf-relay rtp-nte h245-alphanumeric
codec g711ulaw
fax-relay ecm disable
fax rate disable
fax protocol none
icpif 10
expect-factor 5
no vad
dial-peer voice 100 voip
description MG to SBC (non cisco)
destination-pattern 12[3-4].
progress_ind setup enable 3
session target ipv4:10.10.10.2
voice-class h323 1
codec g711ulaw
fax protocol none
icpif 10
expect-factor 5
no vad
dial-peer voice 5 pots
description PRI Out
translation-profile outgoing PSTN
destination-pattern .T
incoming caled-number .
fax rate disable
no digit-strip
direct-inward-dial
port 0/0/0:15
forward-digits all
Thanks for all and any suggestions in advance
Green
Tim,
Can you try adding this :-
incoming called-number .
Retest
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Green
Tim,
So that looks like dial peeer 100 became the best INBOUND match.
How about trying some digit maipulation.
voice translation-rule 301
rule 1 /^12/ /5555/
voice translation-rule 100
rule 1 /^5555/ /12/
voice translation-profile 100TEST
translate called 100
voice translation-profile 301TEST
translate called 301
translation-profile incoming 301TEST
destination-pattern 5555
translation-profile outgoing 100TEST
You will need to try with your preferred DNs - I just suggested translation numbers starting 12.... to 5555... then back again.
Alex.
completely forgot about that approach. I will give it a try first thing monday and get back to you. Until then have a great weekend.
133
