h323 to h323 connections (I'm a bit confused)
I am a bit confused as to what this command does in a voice gateway.
voice service voip
any inputs is highly appreciated. Thanks in advance.
1 ACCEPTED SOLUTION
Re: h323 to h323 connections (I'm a bit confused)
Well, I've seen this mostly in CUBE or CME configurations but nonetheless this command is used to allow (or not allow) specific types of connections thru your CUBE/CME/gateway.  So h323 to h323 allows two h323 endpoints to communicate with each other thru the gateway device.  You might also see sip to sip or h323 to sip based on what you're doing.  With CUBE, h323 to h323  connections are disabled by default and POTS-to-any and any-to-POTS connections are  enabled.  So, the h323 to h323 command enables these types of connections.
Read more considerations here (this is CUBE, but fundamentals are fundamentals):
http://www.cisco.com/en/US/docs/ios/voice/cube/configuration/guide/vb-gw-h323h323.html
Hailey
Please rate helpful posts!
1 REPLY
Hailey
2712
