H323 trunk between uc540 and panasonic ncp500
hi friends,
i am trying to do h323 trunk between uc540 and panasonic ncp500
i am not able to pass the calls between the systems
i am attaching my uc540 config and error log in uc540 while i am trying to call from cisco phone
my uc540 ip 10.0.0.3
ncp500 is 10.0.0.250
i am waiting for good reply
thanks
cyril
Re: H323 trunk between uc540 and panasonic ncp500
HI there,
Rather than trying to decode the HEX, it'd be much more easier if u can grab following
debugs for one failed call attempt:
deb voip ccapi inout
deb h225 asn1
deb h245 asn1
Pl. specify calling/called#  and call direction.
DK
hi dilip,
i am attaching the debug output which you asked
and the details
number 309 is cisco
number 103 is ncp500
calling from cisco to panasonic
thanks
cyril
Panasonic is sending h225 Release Complete with cause (88 - Incompatible Destination)
in response to the setup from Cisco UC5xx:
00939: Oct  7 17:40:19.381: //47/C93B47A6806B/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=88, Retry Count=0)
Not sure what's going on the Panasonic end, but try following on the IOS/UC......
cut-n-paste following at global config prompt (conf t)
voice service voip
no supplementary-service h450.2
no supplementary-service h450.3
h323
  h245 tunnel disable
  h245 caps mode restricted
hi dilip ,
thanks
its is some codec mismatch problem so now between the devices i can call
but i need one more requirement from cisco uc phones i need to take panasonic pri line to call outside mobiles and landline numbers
i created two dial-peers ,the first one is for extension dialing and second one is for to take panasonic pri line and then dial outside.
is it the correct way or else it is worng... and i am dialing like 89050............
in this 8 is to access h323trunk, and normally in panasonic 9 is to dialout and 050.....is outside number.
can u helpme in that
dial-peer voice 5000 voip
description *** CCA BACD ***
destination-pattern 1..
session target ipv4:10.0.0.250
incoming called-number .
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 5001 voip
destination-pattern 8T
no vad
596
