h323 V4 gateway solution
Do all 29XX or 39XX normal voice router will comply h323 V4 or  only ASR 1000 will support this features ? please light me.
Hall of Fame Super Gold
ASR 100 has very little if any voice support or role.
And, what H.323 V4 would, and in what differs ? Is that a bid requirement or something real ?
It is bid requirement, h.323 v4 customer is asking with security enable, do all ordinary voice enable router can we configure h323 v4 security task.
URL - http://www.cisco.com/en/US/docs/ios-xml/ios/sec_data_zbf/configuration/15-2mt/fw-h323-v3v4-sup.html
That is about firewall support, not the voice gateway.
Ask your customer who is the bid competitor, and who he want to buy ultimately.
So we need to include ASA for this bid or security enable voice gateway, can we configure H323 v4 all security related task ?
The router "firewall" do support all the feature in the document that you linked above.
I do not reccomend ASA due to their many limitations, complexity, licensing, and slow developement.
Customer needs h323 V4 gateway setup with security enable, please light me with best h323 voice gateway security enable solution + it should be cost effective.
Cisco routers are always the best solution.
345
