H323 VGW FXO Problem
Greeting All,
A very odd issue we experience each time we change the timezone for the Phones under the Date and time group which is the FXO lines for all the h323 stop working (Inbound and outbound calls) and we have to delete the gateway and re-add it to the cucm to have the FXO work again and this happen each time we change the timezone on the date and time group assigned to the phone.
CUCM is 8.6.
I appreciate your kind Support in this issue.
1 REPLY
Hello, Did you try just to
Did you try just to reset the Gateway from the CUCM after make the changes?
55
