H323 Voice Gateway SIP Trunk To Rightfax
We are trialing a solution for a rightfax installation.
I have the router and the Fax server setup. The router has been in production and sorks fine. We have taken 1 of the available numbers and create a SIP dial peer to divert inbound faxes to the FoIP server.
dial-peer voice 274 voip
destination-pattern 274
session protocol sipv2
session target ipv4:10.10.0.108
incoming called-number .
codec g711ulaw
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
As we already use this in a production environment for all in and outbound calls is there anything else i am missing.
Below are the debugs u have got so far.
002997: Feb 27 10:23:37.483 AEDT: //-1/BE7DFA698357/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=00404542740
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=274
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
002998: Feb 27 10:23:37.487 AEDT: //-1/BE7DFA698357/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x48AE7B84, Call Info(
   Calling Number=00404542740,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=274(TON=Subscriber, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=202, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
002999: Feb 27 10:23:37.487 AEDT: //-1/BE7DFA698357/CCAPI/ccCheckClipClir:
   In: Calling Number=00404542740(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
003000: Feb 27 10:23:37.487 AEDT: //-1/BE7DFA698357/CCAPI/ccCheckClipClir:
   Out: Calling Number=00404542740(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
003001: Feb 27 10:23:37.487 AEDT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003002: Feb 27 10:23:37.487 AEDT: :cc_get_feature_vsa malloc success
003003: Feb 27 10:23:37.487 AEDT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003004: Feb 27 10:23:37.487 AEDT:  cc_get_feature_vsa count is 3
003005: Feb 27 10:23:37.487 AEDT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003006: Feb 27 10:23:37.487 AEDT: :FEATURE_VSA attributes are: feature_name:0,feature_time:1206480800,feature_id:5479
003007: Feb 27 10:23:37.487 AEDT: //5350/BE7DFA698357/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=00404542740(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=274(TON=Subscriber, NPI=ISDN))
003008: Feb 27 10:23:37.487 AEDT: //5350/BE7DFA698357/CCAPI/cc_process_call_setup_ind:
   Event=0x47AE0768
003009: Feb 27 10:23:37.487 AEDT: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 274
003010: Feb 27 10:23:37.491 AEDT: //5350/BE7DFA698357/CCAPI/ccCallSetContext:
   Context=0x48E31420
003011: Feb 27 10:23:37.491 AEDT: //5350/BE7DFA698357/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 5350 with tag 202 to app "_ManagedAppProcess_onramp-sffax"
003012: Feb 27 10:23:37.495 AEDT: //5350/BE7DFA698357/CCAPI/ccCallProceeding:
003013: Feb 27 10:23:37.503 AEDT: //5350/BE7DFA698357/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
003014: Feb 27 10:23:37.503 AEDT: //5350/BE7DFA698357/CCAPI/ccCallDisconnect:
   Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
003015: Feb 27 10:23:37.503 AEDT: //5350/BE7DFA698357/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
003016: Feb 27 10:23:37.567 AEDT: //5350/BE7DFA698357/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x48AE7B84, Tag=0x0, Call Id=5350,
   Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
003017: Feb 27 10:23:37.567 AEDT: //5350/BE7DFA698357/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
003018: Feb 27 10:23:37.567 AEDT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
003019: Feb 27 10:23:37.567 AEDT: :cc_free_feature_vsa freeing 47E96F98
003020: Feb 27 10:23:37.567 AEDT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
003021: Feb 27 10:23:37.567 AEDT:  vsacount in free is 2
Any help is greatly appreciated.
Do i Need an outbound Dial peer specific to this number?
David
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
David,
I am not clear what is not working for you.  Is it inbound from PSTN to RightFax or Outbound from RightFax?
For inbound assuming telco is presenting only 3 digits, i.e. 274 you are fine, for inbound you will need a dial-peer pointing to your PSTN carrier which can be shared with other applications, i.e. CUCM if using H323 or SIP.  What is the PSTN integration you have in place, i.e. is it PRI, SIP trunk, etc?
Also, posting full config would be helpful.
Chris
1 REPLY
David,
Chris
680
