H323 VoIP peer not going to second preference.
I've got a SIP trunk from the carrier coming into a VGW/CUBE. The CUBE converts to H323 to CM 4.1(3). So I have my two VoIP dial-peers for each CM for protocol H323 for incoming calls back to CM. I want to verify that when my first CM goes down, the backup VoIP peer is selected and will route to the backup CM. So I built an access list denying IP any to the primary CM and placed on the CUBE H323 GW. Now the SIP call setup from the carrier keeps re-initializing and the outbound call leg (to CM) never appears to establish amd the phone never rings. debug voice dialpeer shows matching on both dialpeers. I've got my h323 voice class set up with timers. I tried explicitly setting the preference and changing the dialpeer hunt option to use preference first. Any ideas?
THANKS!
voice class h323 1
h225 timeout tcp establish 1
h225 timeout connect 60
h225 timeout setup 1
dial-peer voice 1 voip
preference 1
destination-pattern .T
voice-class h323 1
session target ipv4:10.1.1.1
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 2 voip
preference 1
session protocol sipv2
session target ipv4:192.168.1.1
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 3 voip
preference 2
voice-class h323 1
session target ipv4:10.1.1.2
codec g711ulaw
no vad
Re: H323 VoIP peer not going to second preference.
I would think you need to be more specific in your destination pattern.
If you dial 9 to call out on your Call Manager I would send that 9 to the CUBE and then put something like this in.
voice translation-rule 1
rule 1 /^9/ //
voice translation-profile strip9
translate called 1
dial-peer voice 200 voip
description Incoming From Call Manager Voice
voice-class codec 1
incoming called-number 9T
no vad
dial-peer voice 201 voip
description voip dial peer Out to SIP trunk
translation-profile outgoing strip9
destination-pattern 9T
voice-class codec 1
dtmf-relay rtp-nte digit-drop
no vad
And if your DID range where something like 12125553100 - 12125553199 I would put something like this
dial-peer voice 100 voip
description In from SIP voice
voice-class codec 1
voice-class h323 1
incoming called-number 12125553...
dtmf-relay h245-alphanumeric rtp-nte
no vad
dial-peer voice 101 voip
preference 1
description out to Call Manager voice
destination-pattern 12125553...
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 102 voip
preference 1
voice-class codec 1
voice-class h323 1
no vad
Hope that helps
This isn't a good configuration.
You need to understand that CUBE does not take protocols in to account when looking for dial peers - it is very simplistic.
It will only go by preference and destination-pattern here. In this case, your SIP trunk on dial peer 2 and your CCM on dial peer 1 are equal-cost dial peers. In this scenario, it is possible to load balance between these two dial peers.
You should have the DID range for your CCM in your CCM dial peers. If it is not contiguous, you can use multiple dial peers.
When you do this, only those two dial peers will be matched and you will have fail-over from dial peer 1 to 3.
hth,
nick
236
