h323 with call manager
I have CM with H323 GW i need to use some voice-port for Managers and remaining for other users
and what i need to configure SIP trunk with ITSP
1 ACCEPTED SOLUTION
You need to use 2 sets of RPs
You need to use 2 sets of RPs in CUCM, one for managers, and the other for the rest of the users, then send a different prefix with each one. Configure the DPs to match the prefix and so choose the right port to use. This has been discussed many times before at CSC, you can search for further information.
We recommend a CUBE for SIP trunks, you can also search CSC for this topic and find plenty of information.
java
if this helps, please rate
www.cisco.com/go/pdi
java
thanksi already understand
thanks
i already understand now how to do it with h323 by using different RP with different prefix then match it with dial peer in VG
for the sip lines come from service provider  connected to my VG router what i need
in CUCM i need to configure sip trunk with ip add of VG or ip add of sip server from service providers
in VG i will use translations rule for incoming and outgoing call with dial-peer voip
can you provide me solution for this case
I am guessing you want
I am guessing you want certain calls from Managers go out a certain PRI? You will have to use different prefixes in CUCM and create dial-peers on the gateway to send calls out the specific PRI based on the prefix. You will have to create separate CSS/partitions to add different prefixes.
Please rate useful posts.
47
