h323chan_chn_sm: Connect Failed on AS5350XM H323 Gateway
We have a problem of high abandon voip calls.
The system is using H323 protocol.
From one of the AS5350XM servers, we found high number of h245 failures compared to other AS5350XM.
A debug on h245 events showed:
Dec 27 18:18:29.575 AEST: Changing to new event: CONNECT
h323chan_chn_connect: connecting to 10.188.59.187:1720
Dec 27 18:18:29.575 AEST: h323chan_gw_conn: Created socket fd=-1
Dec 27 18:18:29.575 AEST: h323chan_gw_conn: socket failure: errno=5 errstr=I/O errorh323chan_chn_connect: h323chan_gw_conn failed, error 5
Dec 27 18:18:29.575 AEST: h323chan_chn_sm: Connect Failed
Dec 27 18:18:29.579 AEST: h323chan_chn_process_read_socket: fd=2 of type CONNECTED has data
Dec 27 18:18:29.615 AEST: h323chan_chn_process_read_socket: fd=2 of type CONNECTED has data
sh h323 gateway cause-codes showed this:
38 network out of order ( 41 438509
41 temporary failure (41) 2731 1576
42 switch congestion (42) 8 0
44 no requested circuit ( 38 0
47 no resource (47) 60 2068377
1 REPLY
Re: h323chan_chn_sm: Connect Failed on AS5350XM H323 Gateway
All the reason codes you are getting are related to congestion. I would start checking if you get the dropped calls only during peak hours and your channels are really busy.
You can also check this bug that affects IOS 12.3 CSCsb21047
169
