Half-duplex calls from remote users
Andy Infante
I have a call manager 4.1(2) system connected with a 2811 gateway and T1 with remote users who have VPN connections through internet via ASA (attached with 6MB pipe). The T1 is for PSTN calls. Users who call from remote sites (single users with DSL or cablemodem links) to each other (not to central site) will almost always have to make 2 calls. The first call will have one party not able to speak and/or hear the other end. Any ideas??
9 Replies 9
paolo bevilacqua
Most likely these are the firewall/asa/vpn that you have in the audio path,you need to make sure no internal activity is blocked or inspected.
What about the fact that it doesn't happen all the time?
Sometime the security appliances behave a little strangely, due to timeouts, etc a flow may or may be not blocked.
Ok, so I do have inspect in global policy...what do I disable?
policy-map global_policy
class inspection_default
inspect dns migrated_dns_map_1
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect sip
inspect sqlnet
inspect sunrpc
inspect tftp
inspect xdmcp
class class-default
Disable inspection globally.
Disable all inspection? This is our company firewall. Won't that allow some things to be missed?
Ok, so I've disabled all inspection and the problems are still present. Since not all my users have the same problem, but are fairly consistent with highest bandwidth DSL or cablemodem isp connection, what other options can I tweak to see what makes a difference? Some users have older vpn clients and ip communicator, also some using Anyconnect. Other users have ipsec tunnel with dedicated 803 router and 7912 phone. No consistency in the problems...mostly problems with users on vpn client and softphone.
You may want to check out this doc - it can help you narrow down exactly where the problem is.
-nick
Should the call appear in the output the whole time is it connected? One user who I tested this with couldn't hear or talk, and even her dialtone came out as clicks and dashes. Voice, if it ever came through was choppy and intermittent. Running command above had the call appear briefly, then no longer, like it was disconnected, but her call to me was still running on both our phones, with no communication possible...how is that?
