Handling VXML transfer hang-ups
I'm developing a VXML application which makes use of transfer.
<transfer name="transfercall" destexpr="'tel:' + prefixedDestination + ';phone-context=0'" type="bridge" connecttimeout="15s" maxtime="600s" cisco-aniexpr="'tel:' + '4000'" >
      <filled>
          <!--Here I handle the result of transfercall-->
      </filled>
</transfer>
Cisco configuration:
application
     service transfer transfer.vxml
dial-peer voice 2000 voip
description **Incomming Call to SIP Trunk**
service transfer
voice-class codec 100
voice-class sip dtmf-relay force rtp-nte
session protocol sipv2
session target sip-server
incoming called-number 4000
dtmf-relay rtp-nte
no vad
Consider the following scenario's:
Caller = 1000
Callee = 2000
Caller calls 4000 and the VXML is executed. Inside the VXML a bridged transfer is performed to 2000 and 2000 picks up.
Here is where I'm having problems. Whenever 2000 hangsup the transfercall variable in my transfer element is set, this is okay. However when 1000 hangs up, the transfercall variable is undefined. I know this is because the VXML does not continue when 1000 hangs up because the whole session is thrown away.
I need to know what the result was of the transfer in both cases, because I'm logging these results. I created my own model where an ACallLeg is the incoming call and a BCallLeg is an outgoing call. The BCallLeg needs a status, but in my situation I'm only able to supply one when the callee hangs up.
Does anyone know how to get the outcome of a transfer, regardless of which party hangs up? Or do I need to consider programming in TCL?
Kind regards,
Grant
Everyone's tags (3)
450
