12-27-2009 09:40 AM - edited 03-15-2019 08:54 PM
I have a critical requirement. Can someone help me on this:
I Have 3 ISDN PRI links terminating on Cisco 2821 Routers. 2 Links in one 2821 & 1 link in 1 Router. These PRI details are listed below:
PRI (1) 30c - 04 8704000
PRI (2) 30c - 04 8704200
PRI (3) 30c - 04 8704400
Is the following possible?
Business Centre A: 048704400 (Main/reception number) to 443 with 10 channel
Business Center B: 048704444 (Main/reception number) to 599 with 10 channel
Business Center C: 04870200 (Main/reception number) to 299 with 10 channel
Business Center D: 04870300 (Main/reception number) to 399 with 10 channel
Business Center E: 048704000 to 199 (Main/reception number) to 199 with 20 channel.
I have CUCM 7.1.2 & my Gateways are registered as MGCP to CUCM.
Can someone suggest me whether this is possible or not...
Rgds,
Partha
12-27-2009 10:55 AM
Certainly not possible with MGCP.
If using H.323 or SIP, you can use max-conn or trunk-groups to limit number of calls per destination.
12-27-2009 11:05 AM
12-27-2009 01:08 PM
As mentioned before, separated DPs per number, and max-conn.
Please remember to rate useful posts clicking on the stars below.
12-27-2009 06:58 PM
you can control outbound calls using the metheds mentioned by Paolo ( what cahnnel/line to use ) but inbound call controled by the Telco
you may contact them and see if they can help you to get the inbound calls setup as you want
good luck
if helpful Rate
12-28-2009 12:36 AM
OP only needs to limit number of calls toward certain numbers, not to control the specific channel used.
Consequently, max-conn under voip DP will suffice for calls inbound to CM.
12-27-2009 10:57 PM
Can I control inbound as well as Outbound calls as per your
suggestion....other members on the same topic has told that Outbound
calls can be controlled but not inbound calls. Can u kindly suggest or
can share some doc with me...
Rgds,
partha
12-28-2009 12:34 AM
This limits call from telco to CM.
From what I understand, other way around is not of interest for you.
12-28-2009 01:28 AM
Thanks a lot for your generous reply...
So my requirement will be meet as per your suggestion. Based upon your
suggestion I am committing to the end customer....Kindly share some doc
if possible..
12-28-2009 04:23 AM
There are no special docs for this, standard documentation applies.
