Community Member
Harddrive size for CM4 to 6 upgrades
CM 6.1 release notes state that a minimum of 72 GB drives are required for a CM4 to CM6 upgrade.
I am going to be upgrading MCS-7835H-3.0-IPC1 from CM 4.1 to CM 6.1.
Can I order hard drives bigger than 72 GB for this upgrade? Has anyone done this? are there any links with supported HD sizes for this upgrade?
Re: Harddrive size for CM4 to 6 upgrades
I think the installer does look out for 72 gb disks, although i have installed this on 7825 H3 servers with SATA drives 160gb each.
Silver
70GB is clearly defined as a 'minimum' requirement.
105
