Hardening IP HTTP SERVER. What application session modules are required for speeddial.xml?
My normal operation is to disable ip http server and ip http secure-server on all routers and switches.  I have a CME deployment where a speed-dial menu is desired/required and it is my understanding this will require the HTTP server to be enabled on the CME/router.  Along with using ip http access-class to control access, I would like to disable all application session modules not required for a speed-dial menu.  What are the minimum HTTP server application session modules required for the speed-dial menu?
System is running IOS 15.3(3)M2/CME 10.0
Alan
17
