Hardware Based PRI monitoring
Is there any such device which does Hardware based PRI moniroring ? The idea is that PRI cable is not inserted into the Voice gateway etc but into that specific device and then from that device to the voice gateway .
PRI LINE ----> MONITORING DEVICE -------> VOICE GATEWAY ------> Internal network
I'd like to ask what type of monitoring you want to achieve.
Please rate replies and mark question as "answered" if applicable.
something like this
http://www.prilink.com/priStarter.php
Is there a solution in cisco or with some other known vendor ?
As far as I know Cisco has none.
We monitor our customer's PRIs using Cacti. Links below might help.
http://forums.cacti.net/about21469.html
http://www.gossamer-threads.com/lists/engine?list=cisco&do=search_results&search_forum=forum_5&search_string=pri+usage&search_type=AND
Don't forget to rate this post if this helps you.
409
