Community Member
Hardware Compartability With CUCM version 8
Dear All,
we have a plan to upgrade CUCM ver 7 to ver 8 our server series is MCS-7835H2.
is this hardware support CUCM ver 8 ?
Kindly advice
1 REPLY
Bronze
Re: Hardware Compartability With CUCM version 8
Hi there,
if you're running 7.x on there successfully then running 8.x should be okay, but ensuring you have 4GB of RAM and 146GB of HDD space is recommended.
from the following link
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
MCS 7835
2 GB for -H2, -I2 and older. For version 8.0(3) or higher, 4 GB strongly recommended.
4 GB for -I3
72 GB for -H2, -I2 and older. For version 8.0(3) or higher, 146 GB strongly recommended.
146 GB for -I3
regards,
Paul
277
