Hardware Conferencing CM 6.1.2
I am trying to implement hardware conferencing in an environment that uses multiple codecs. My understanding is that a CM software conferencing bridge only supports G711 codec and puts overhead on the server, so I am looking to use a hardware conferencing bridge i.e. a DSP resource on a 3845 router. I need to be able to support 1 conference of up to 16 participants. I have a couple of questions.
1. Can you point me to a pre-existing example configuration or instructions for configuration?
2. Is SCCP required for the hardware conferencing bridge to work?
3. Can hardware conferencing support 16 participants? I have read on this forum that the maximum is 8 but have also read a document stating the maximum is 16.
Jeremy
VIP Super Bronze
Re: Hardware Conferencing CM 6.1.2
Jeremy,
Here is a working configuration of CFB...
voice-card 0
no dspfarm
dsp services dspfarm
sccp local GigabitEthernet0/0
sccp ccm 10.x.y.1 identifier 2
sccp ccm 10.x.y.2 identifier 3
sccp ccm 10.a.b.10 identifier 1
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate ccm 2 priority 2
associate ccm 3 priority 3
associate profile 1 register CFB1_LON
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 16
associate application SCCP
You can use this link for configuration uide. Its excellent
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00807f8b30.shtml
2. Yes SCCP is required
3. I believe the maximum participant per session is 8 for the new DSPS (PVDM2-)
It may have changed. You can send a link to the document and I will have a look for you.
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hi Deji,
Thanks a lot for this. I found another document today that seemed to indicate a maximum of 32 participants is possible provided 12.4(15)T IOS is running, at http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/media.html#wp1046210
"Starting with Cisco IOS Release 12.4(15)T, this limit on the maximum number of participants has been increased to 32."
Jeremy
according to the documentation that's only for meet-me
maximum conference-party
http://www.cisco.com/en/US/docs/ios/voice/command/reference/vr_m1.html#wp1404791
and it's still completely dependant on the codecs you configure, only g711/g729
it still can take a little overhead from the server if you're going to use only those codecs.
java
if this helps, please rate
java
www.cisco.com/go/pdi
This may still work then, as meet-me is what I am after (as opposed to adhoc), and my phones will be using g711/g729 codecs.
So could I configure the following:
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 1
maximum conference-party 16
and expect 1 DSP resource at most to be used for conferencing?
Jeremy
VIP Super Bronze
Jeremy,
A DSP farm that is configured for conferencing and G.711 provides 8 conferences. When configured to accept both G.711 and G.729 calls, a single DSP provides 2 conferences because it is also reserving its resources for performing transcoding of streams.
So with G.711/G.729 each DSP will provide 2 conferences with each conference session supoorting 8 0r 32 participants depending on your IOS.
Assuming your IOS supports 8 participants, then with a single dsp..you will have 2*8= 16 streams. So yes your config will be fine.
There are two types of hardware conferencing Ad-Hoc and Meet-Me conferencing. With Adhoc conferencing you are right max is 8 participants (codec supported are g.711/g.729a/g.729). But if you use Meetme conferencing with multiple codec your max is 1 conference with 16 participants per DSP. You can add more PVDM2-64 (your model supports 4 DSP slots) and that will give you a second Meet-me conference with 16 participants but unfortunately you can not mixed or combine 2 dsp's for one conference. If you use pure g.711 codec you'll get the max 64 participants per DSP.
Reference: CME4.1 Hardware Conferencing Tech Tips (May 15, 2007) by Tony Huynh
I know reference is for CME 4.1 and 2 years old but I use it to configure my CME 7.1. good luck I hope that answers your question.
Thank you very much; I believe I now have enough information to proceed.
Thanks again,
Jeremy
192
