Bronze
Hardware Detection-Help
Hi forum friends, Just one question, a client have puchased a HP Proliant-380G5 with all parts and hardware accepted by Cisco, I have the CCM 4.1 Software (with Hard Detection for OS 2000.2.4 and OS 2000.2.7) but the cd reject the server. Do I need another Hard Detection for other SO version, for example 2000.4.4 or 2003.1.1. Do I'm right?
Thanks a lot
1 REPLY
Silver
Re: Hardware Detection-Help
which is the callmanager version you are trying to install? Fro callmanager 4.1part that you will need is CM4.1-K9-380G5-1 for your HP Proliant DL380-G5
102
