Community Member
HArdware specification
Dear cisco,
Can anyone help us to provide me Call manager Hardware Specification MCS we have 3000 users requirement...
You don't want to go with MCS, you should be looking into a UCS or 3rd party spec based servers.
http://docwiki.cisco.com/wiki/UC_Virtualization_Supported_Hardware
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Community Member
Dear Jaime,
Many thanks for your update but we want to use 7.1.5 CUCM for our business because its using one of our client is using 7.1.5 which suitable for us and there is MSC server not UCS I know UCS is good for future upgrade and advance technology but we want to use 7.1.5 could u please tell me what kind of hardware specification for MCS server for 3000 users..
Hall of Fame Super Silver
If this is a separate deployment, why do you care what one of your clients is using? You should go with latest software and hardware and not 5 year old software and discontinued hardware.
HTH.
Chris
Good luck with that, all the MCSs have been sold out, you probably can find an used server.
You would need a 7845 series.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/callpros.html#wp1043871
java
java
Community Member
Thanks Jaime this is helpfull for me I will discuss with our management and come back to you....
Community Member
which call manager version do you have. Go for cisco UCS servers instead.
http://www.cisco.com/en/US/products/ps10493/prod_models_comparison.html
Hall of Fame Super Red
Hi Syed.
Just wanted to add that both CUCM 7.1 and the 7845 MCS series
have been anoounced as EoL (End of Life)
End-of-Sale and End-of-Life Announcement for the Cisco Unified Communications Manager 7.1
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps556/end_of_life_notice_c51-695269.html
End-of-Sale and End-of-Life Announcement for the Cisco 7800 Series Media Convergence Servers
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/end_of_life_notice_c51-728040.html
And this note from the doc linked above;
Product Migration Options
There  is no replacement for the Cisco 7800 Series Media Convergence Servers.  Customers are encouraged to migrate to virtualization either on the  Cisco Unified Computing System or on third-party servers satisfying the  requirements of Cisco Collaboration's support policy.
Cheers!
Rob
"Your life is worth much more than gold."
- Bob Marley
Community Member
Dear ROB,
could you provide UCS Hardware specification for Call manager 8. or higher support for 3000 users requirement...
Our management decided to go with UCS servers...
VIP Super Bronze
Java already gave it to you..Below are the links you need. Study them and make sure you know exactly what is required!
http://docwiki.cisco.com/wiki/Unified_Communications_Virtualization_Sizing_Guidelines
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
189
