Community Member
Have a Cisco Ip Phone 521S -- # CP-521SG I cannot login with CCA since v1.8 or v2.2 And Screen is showing Downloading process permanently. What happend here!!?
using v2.2 of CCA the screen of login with user privileges Admin appear, but, i put    user: cisco   passwd: cisco, and does nothing.
i only have the Phone ( 8 of them ), and need to use with asterisk.
in the screen appear this tree frames in anytime:
    Downloading
XMLDefault.cnf.xml
        Downloading
XMLDefault524G.cnf.xml
          Downloading
SEP00211BFCA468.cnf.xml
Thanks for any helpfull reply.
Everyone's tags (3)
1 REPLY
Community Member
Re: Have a Cisco Ip Phone 521S -- # CP-521SG I cannot login wi
Your Phone tries to net-load its configuration from you
Cisco Unified Communication Aplliance.
The CP-52X Phones are for the Cisco Unified Communication System,
not for SIP (and asterisk) . Yes, the look very much the SPA- Version.
For SIP, use the (formerly Linksys) Small Business Phones
SPA-9XY .
With SPA 922, 942, 962 you will get backlight display and more cpu in the phone
so they may built SSL/TLS Connection to their Centrex.
(and they will be PoE, so you may need to order the external powersupply).
With SPA 921, 941, you will get NO Backlight and NO non-english Menues.
I personally recommend the SPA525G which has color-display,
5 lines, works with SIP or with Cisco Unified Communication
or with the SPA9000 IP-PhoneSystem
(it's POE, order an external powersuply).
Missing is just a li-ion accu pack since the phone can work over WLAN.
It may also user your ldap/active directroy for retrieving phone numbers.
(AFAIK also on the SPA-9x2 phones possible).
Jürgen.
865
