Having to re-create cnf-files when router reboots
                   Using CME. I am having to re-create 8945 cnf-files when the router reboots. Not sure why this happening. My sip phones register just fine. Just FYI: First time configuring any Cisco IP Telephony.
Current config:
telephony-service
video
max-ephones 24
max-dn 48
ip source-address 192.168.125.1 port 2000
cnf-file location flash:
cnf-file perphone
load 8945 sccpcmterm8945.cop.sgn
voicemail 1000
max-conferences 8 gain -6
web admin system name admin password cisco
dn-webedit
time-webedit
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1
number 1100
name EPHONE1
call-forward noan 1000 timeout 10
no huntstop
ephone-dn  2
number 1101
name EPHONE2
no huntstop
ephone  1
device-security-mode none
video
mac-address 8478.ACED.AE31
username "user1" password cisco
type 8945
button  1:1
ephone  2
video
mac-address 8478.ACED.AD87
username "user2" password cisco
type 8945
button  1:2
Any suggestions, recommendations?
Jeff
1 ACCEPTED SOLUTION
Re: Having to re-create cnf-files when router reboots
Can you use the below , please?.and delete the other loads and make sure your flash containd the below files. I found on the above configuration after alias is incorrect , should be as the below.
telephony-service
load 8945 SCCP8941_8945.9-3-4-17     (try this if not please try this "load 8945 SCCP8941_8945.9-3-4-17.loads")
BOOT8941_8945.0-0-1-0.bin.sgn
SCCP8941_8945.9-3-4-17.bin1.sgn
SCCP8941_8945.9-3-4-17.bin2.sgn
SCCP8941_8945.9-3-4-17.bin3.sgn
SCCP8941_8945.9-3-4-17.bin4.sgn
SCCP8941_8945.9-3-4-17.bin5.sgn
SCCP8941_8945.9-3-4-17.bin6.sgn
SCCP8941_8945.9-3-4-17.bin7.sgn
SCCP8941_8945.9-3-4-17.bin8.sgn
SCCP8941_8945.9-3-4-17.bin9.sgn
Thank you
please rate all useful information
Initially we always point the phone towards the TFTP server. From the TFTP server phone fetches its *.cnf.xml file which gives it varoius information such as :
1. Call Agent Ip
2. Protocol
3. Date time templates
4. Ip phone services
Please try the below:-
1- under telephony-service
no cnf-file location flash:
no cnf-file perphone
create cnf-files.
2-If the files of your phones are located on your flash , please share with us. You can use it on the config mode as the below:-
tftp-server flash:flash/kern9971.9-1-1SR1.sebn  alias   kern9971.9-1-1SR1.sebn
tftp-server flash:flash/rootfs9971.9-1-1SR1.sebn   alias rootfs9971.9-1-1SR1.sebn
Thank you
I have the files in flash:
tftp-server flash0:/ipphones/8945/SCCP8945/BOOT8941_8945.0-0-1-0.bin.sgn alias boot8945.bin.sgn
tftp-server flash0:/ipphones/8945/SCCP8945/SCCP8941_8945.9-3-4-17.bin1.sgn alias 8945.bin1.sgn
tftp-server flash0:/ipphones/8945/SCCP8945/SCCP8941_8945.9-3-4-17.bin2.sgn alias 8945.bin2.sgn
tftp-server flash0:/ipphones/8945/SCCP8945/SCCP8941_8945.9-3-4-17.bin3.sgn alias 8945.bin3.sgn
tftp-server flash0:/ipphones/8945/SCCP8945/SCCP8941_8945.9-3-4-17.bin4.sgn alias 8945.bin4.sgn
tftp-server flash0:/ipphones/8945/SCCP8945/SCCP8941_8945.9-3-4-17.bin5.sgn alias 8945.bin5.sgn
tftp-server flash0:/ipphones/8945/SCCP8945/SCCP8941_8945.9-3-4-17.bin6.sgn alias 8945.bin6.sgn
tftp-server flash0:/ipphones/8945/SCCP8945/SCCP8941_8945.9-3-4-17.bin7.sgn alias 8945.bin7.sgn
tftp-server flash0:/ipphones/8945/SCCP8945/SCCP8941_8945.9-3-4-17.bin8.sgn alias 8945.bin8.sgn
tftp-server flash0:/ipphones/8945/SCCP8945/SCCP8941_8945.9-3-4-17.bin9.sgn alias 8945.bin9.sgn
tftp-server flash0:/ipphones/8945/SCCP8945/SCCP8941_8945.9-3-4-17.loads alias 8945sccp.loads
tftp-server flash0:/ipphones/8945/SCCP8945/cmterm-8941_8945-sccp.9-3-4-17.cop.sgn alias sccpcmterm8945.cop.sgn
Can you check the below?.
create cnf-files
Thank you
Did the
create cnf-files
Then rebooted the router.
Getting this from debug tftp events:
Oct 15 21:42:09.971: TFTP: Looking for CTLSEP8478ACEDAE31.tlv
Oct 15 21:42:10.011: TFTP: Looking for ITLSEP8478ACEDAE31.tlv
Oct 15 21:42:10.049: TFTP: Looking for SEP8478ACEDAE31.cnf.xml
Oct 15 21:42:10.049: TFTP: Opened flash:/its/SEP8478ACEDAE31.cnf.xml, fd 14, size 3780 for process 58
Oct 15 21:42:10.061: TFTP: Finished flash:/its/SEP8478ACEDAE31.cnf.xml, time 00:00:00 for process 58
Oct 15 21:42:13.068: TFTP: Looking for SIP_English_United_States/gb-sccp-sip.jar
Oct 15 21:42:13.394: TFTP: Looking for SIP_United_States/g3-tones.xml
Oct 15 21:42:13.950: TFTP: Looking for CTLSEP8478ACEDAD87.tlv
Oct 15 21:42:13.990: TFTP: Looking for ITLSEP8478ACEDAD87.tlv
Oct 15 21:42:14.030: TFTP: Looking for SEP8478ACEDAD87.cnf.xml
Oct 15 21:42:14.030: TFTP: Opened flash:/its/SEP8478ACEDAD87.cnf.xml, fd 14, size 3779 for process 58
Oct 15 21:42:14.042: TFTP: Finished flash:/its/SEP8478ACEDAD87.cnf.xml, time 00:00:00 for process 58
Oct 15 21:42:17.077: TFTP: Looking for SIP_English_United_States/gb-sccp-sip.jar
Oct 15 21:42:17.407: TFTP: Looking for SIP_United_States/g3-tones.xml
Not registering phones!
So I did the following:
Router(config)#telephony-service
Router(config-telephony)#create cnf
Router(config-telephony)#create cnf-files
Creating CNF files
Router(config-telephony)#exit
Router(config)#exit
rebooted the phones and now get this:
Oct 15 21:48:52.242: TFTP: Looking for CTLSEP8478ACEDAE31.tlv
Oct 15 21:48:52.280: TFTP: Looking for ITLSEP8478ACEDAE31.tlv
Oct 15 21:48:52.318: TFTP: Looking for SEP8478ACEDAE31.cnf.xml
Oct 15 21:48:52.946: TFTP: Opened system:/its/vrf1/XMLDefault8945.cnf.xml, fd 14, size 1375 for process 58
Oct 15 21:48:52.948: TFTP: Finished system:/its/vrf1/XMLDefault8945.cnf.xml, time 00:00:00 for process 58
Oct 15 21:48:54.265: TFTP: Looking for CTLSEP8478ACEDAD87.tlv
Oct 15 21:48:54.303: TFTP: Looking for ITLSEP8478ACEDAD87.tlv
Oct 15 21:48:54.337: TFTP: Looking for SEP8478ACEDAD87.cnf.xml
Oct 15 21:48:54.337: TFTP: Opened system:/its/vrf1/XMLDefault8945.cnf.xml, fd 14, size 1375 for process 58
Oct 15 21:48:54.347: TFTP: Finished system:/its/vrf1/XMLDefault8945.cnf.xml, time 00:00:00 for process 58
Oct 15 21:48:55.965: TFTP: Looking for sccpcmterm8945.cop.sgn.loads
Oct 15 21:48:56.015: TFTP: Looking for English_United_States/gb-sccp-sip.jar
Oct 15 21:48:56.341: TFTP: Looking for United_States/g3-tones.xml
Oct 15 21:48:57.348: TFTP: Looking for sccpcmterm8945.cop.sgn.loads
Oct 15 21:48:57.398: TFTP: Looking for English_United_States/gb-sccp-sip.jar
Oct 15 21:48:57.718: TFTP: Looking for United_States/g3-tones.xml
Oct 15 21:49:00.686: %IPPHONE-6-REGISTER: ephone-1:SEP8478ACEDAE31 IP:192.168.125.12 Socket:1 DeviceType:Phone has registered.
Oct 15 21:49:02.067: %IPPHONE-6-REGISTER: ephone-2:SEP8478ACEDAD87 IP:192.168.125.11 Socket:2 DeviceType:Phone has registered.
Phones have registered. BUT if I go out and reboot the router, they will not be able to register until I manually create the cnf-files and reboot the phones...
I have no idea why this is happening...
Jeff
your have to do the below
telephony-service
no load 8945 sccpcmterm8945.cop.sgn
load  8945 sccpcmterm8945.cop.sgn.loads
no create cnf-files
create cnf-files
Thank you
Still same issue but getting this error when during bootup of router:
LOAD COMMAND ERROR:cnf-file location system is not supported for creating automatic tftp bindings. Please use file location flash | slot0 | tftp OR create tftp bindings manually
My sip phone are doing just fine. I may just upgrade the 8945 from sccp to sip and see if that helps.
Thanks for all your input..
telephony-service
Thank you
OK.. I have removed the tftp-server information on these files.
I tried to added the "load 8945 SCCP8941_8945.9-3-4-17" but asked for file location.
I added the "cnf-file location flash:".
Added the "load 8945 SCCP8941_8945.9-3-4-17" and it accepted it.
I them moved the files to flash:/its/ folder..
Rebooted router and the phone were able to re-register. This is very good. Thank you...
One quick question though... The information on the phone says the app load is SCCP 9-3-1-19 not the SCCP 9-3-4-17 that we were trying to load. I don't think it has ever loaded. Should it be loading the SCCP 9-3-4-17?
Thanks.
Hi Jeff
Congratulation that your issue fixed , please donot forget to rate all useful posts to make it easier for the search for good posts related to same issue which you got.
For the Q
1-Please check the flash .
2-Try to do
no create cnf-files
create cnf-files
3-Do reset factory to the phone and check.
Thank you
Thank you Jeff for rating and  you are so welcome anytime , please remeber that you friend Islam is here and ready to help you for any issue.
490
