HDD and RAID
goranr
How can I check status of HDD in RAID on CCM 6.X?
How do I know remotely that disks are OK?
Best regards
Jaime Valencia
this is the closest we have for remote monitoring
Command Line Interface
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/6_1_1/cucos/iptpappa.html#wp1007671
show hardware
show status
java
if this helps, please rate
java
5 Replies 5
Jaime Valencia
show hardware
show status
java
java
We have 7835 with array of disc "RAID", one of the two hard disks has me a little worried because the led isn't lit
Is this normal?
I will get show hardware and show status.
Nop thats not normal, normally activity LED should blink.
Which led?
The output here will help.
You can run HW diagnostics using HP smart start CD from HP site and boot the server, and select running the most detailed diags.
check App and Sylog viewer as well.
This issues is bouth server subcriber and publisher.
I have this:
CISCO UNIFIED COMMUNICATIONS MANAGER 6.1(2) System Installation DVD
CISCO UNIFIED COMMUNICATIONS MANAGER 6.1(2) System Recovery CD
Do I have the correct cd's?
The led that does not lit has form of hard disk "cylinder" this behavor is in just one of the two hard disk but is in both servers
I went to see the client and removed the hard disk that had the led lit, after that I restart the server and validete the services.
This indicates me that hard disk operates normally and that this behavior is normal in the servants HP. Nevertheless the client wants a documented explanation of the behavior, Do you have some information above this behavior?
I attach show hardware and show status
