HDD failure in CUCM Subscriber MCS 7825 I4
Hi All,
I found an HDD Failure issue in my CUCM Subscriber. As of now only the secondary HDD is Online. Below is the show Hardware output. Shall i raise an RMA for the same or shall i once reseat the HDD. My query is if i reseat the existing HDD or the new HDD, Shall i make the server shoutdown and do it? Are there any other challenges?
RAID Version      :
Raid firmware version: 1.30.05.00
Raid Bios version: 6.30.00.00
BIOS Information  :
IBM IBMBIOSVersion1.45-[M9E145AUS-1.45]- 11/12/2010
RAID Details      :
LSI Logic IR Configuration Utility 2.06.01
Read configuration has been initiated for controller 0
Controller information
Controller type                         : SAS1064E
  BIOS version                            : 6.30.00.00
  Firmware version                        : 1.30.05.00
  Channel description                     : 1 Serial Attached SCSI
  Initiator ID                            : 112
  Maximum physical devices                : 62
  Concurrent commands supported           : 277
  Slot                                    : 0
  Bus                                     : 1
  Device                                  : 0
  Function                                : 0
  RAID Support                            : Yes
IR Volume information
IR volume 1
  Volume ID                               : 2
  Status of volume                        : Degraded (DGD)
  RAID level                              : 1
  Size (in MB)                            : 237464
  Physical hard disks (Target ID)         : 4 3
Physical device information
Initiator at ID #112
Target on ID #3
  Device is a Hard disk
  Enclosure #                             : 1
  Slot #                                  : 1
  Connector ID                            : 1
  Target ID                               : 3
  State                                   : Failed (FLD)
  Size (in MB)/(in sectors)               : 238475/488397168
  Manufacturer                            : IBM
  Model Number                            : WD2502ABYS-23B7A0
  Firmware Revision                       : 02.03B05
  Serial No                               :      WD-WCAT1F802682
  Drive Type                              : SATA
  Protocol                                : SATA
Target on ID #4
  Enclosure #                             : 1
  Slot #                                  : 0
  Connector ID                            : 0
  Target ID                               : 4
  State                                   : Online (ONL)
  Manufacturer                            : IBM
  Serial No                               :      WD-WCAT1F802489
  Drive Type                              : SATA
  Protocol                                : SATA
Sankar.
  • IP Telephony
1 REPLY
As you can see from the output, RAID1 is configured (mirroring). You need to RMA the faulty Hard Drive. Cisco will send the same HD (seize/model) and when you plug in the new disk, it will rebuild from the working one. See the link below:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/trouble/7_1_2/tbsystem.html#wp1190377
Please rate helpful answers!
609
