headsets
This is for a Contact Center - all users have headsets.
Requirement is that when an Agnet gets a call the ringing is heard only by the Agent in his/her headset and not by other people.
How do you configure CM for this requirement?
1 ACCEPTED SOLUTION
Silver
Re: headsets
It is not possible to configure ringtone only on headset. If you require a ziptone to the headset instead of ringing the phone, the agent DN will have to be configured for auto-answer.
Silver
Re: headsets
Re: headsets
Thanks for the advise. I've rated your post.
Re: headsets
But can you explain what happens when agent has headset and auto-answer mode?
The call is simply connected or the user is warned before with some kind of sound (bip) ?
thanks,
met.
Re: headsets
user hears one beep then gets connected to the caller
171
