Hello friends, I wanted to ask what was the file system directory-structure of the CUCM 7.x, 8.x My purpose is to delete files in specific folders to clean the hard disk through the CUCM CLI, but you must know the configuration of the directory to search
Hello friends,
My  purpose is to delete files in specific folders to clean the hard disk  through the CUCM CLI, but you must know the configuration of the  directory to indicate the search path
(Eg: delete file <file spec>, or the path)
VIP Super Bronze
Reply
Your access to the file system is very limited. What you will be able to see from the administrator CLI is essentially just log file directories. Deleting files from them manually isn't really advisable either.
Anyways, you can see the directories you're allowed to interact with by typing
admin:file list
      file list activelog
      file list inactivelog
      file list install
      file list license
      file list partBsalog
      file list salog
      file list tftp
After that you see directories within like this:
admin:file list activelog platform/cli/*
mycapture.cap
dir count = 0, file count = 1
The rest of the file commands work similar to this and are documented in the Command Line Interface Reference Guide for Cisco Unified Communications Solutions Release 8.0(2).
Re: Reply
Hello Jonathan,
thanks for the suggestion.
My problem is to know the structure of the sub directory (such as "platform"): in other words platform is located in what way? It is accessible only because there are log files? What are the other folder sibling of "platform"? The directory-type "usr", "dev" "etc" are?
Francesco
VIP Super Bronze
Re: Reply
Correct, you can only access it because it contains log files that would be accessible to you through RTMT. You cannot access any of the POSIX file system such as /etc /dev /opt. This is a consequence of sealed appliance model.
194
