Help 2651XM, NM-HDV2-2T1/E1 & VIC-2FXO= Amber lights
johnsont
Trying to put together a CCNA Voice Lab from spare parts..
So far I Have a 2651XM with NM-HDV2-2T1/E1 & VIC-2FXO= installed in the slot on the NM-HDV2.
VIC-2FXO has amber lights.  Any ideas??
Router#sho ver
Cisco IOS Software, C2600 Software (C2600-IPVOICEK9-M), Version 12.4(25d), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 18-Aug-10 04:49 by prod_rel_team
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
Router uptime is 13 minutes
System image file is "flash:c2600-ipvoicek9-mz.124-25d.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2651XM (MPC860P) processor (revision 4.1) with 253952K/8192K bytes of memory.
Processor board ID FTX0942A2TS
M860 processor: part number 5, mask 2
2 FastEthernet interfaces
2 Channelized (E1 or T1)/PRI ports
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
Router#sho diag
Slot 0:
        C2651XM 2FE Mainboard Port adapter, 2 ports
        Port adapter is analyzed
        Port adapter insertion time 00:09:07 ago
        EEPROM contents at hardware discovery:
        Hardware Revision        : 4.1
        PCB Serial Number        : FOC09321EJ6
        Product (
        Chassis Serial Number    : FTX0942A2TS
        Part Number              : 73-7756-06
        RMA History              : 00
        RMA Number               : 0-0-0-0
        Board Revision           : B0
        Deviation Number         : 0-0
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF 40 03 6F 41 04 01 C1 0B 46 4F 43 30 39 33
          0x10: 32 31 45 4A 36 CB 12 FF FF FF FF FF FF FF FF FF
          0x20: FF FF FF FF FF FF FF FF FF C2 0B 46 54 58 30 39
          0x30: 34 32 41 32 54 53 82 49 1E 4C 06 04 00 81 00 00
          0x40: 00 00 42 42 30 80 00 00 00 00 FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Slot 1:
        High Density Voice NM-HDV2-2T1/E1 Port adapter
        Port adapter insertion time 00:08:54 ago
        Hardware Revision        : 1.1
        Top Assy. Part Number    : 800-22168-03
        Board Revision           : C0
        Fab Version              : 04
        PCB Serial Number        : FOC12121GCF
        RMA Test History         : 00
        RMA History              : 00
        Fab Part Number          : 28-6126-04
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        Field Diagnostics Data   : 00 00 00 00 00 00 00 00
        Product (FRU) Number     : NM-HDV2-2T1/E1
        Version Identifier       : V03
          0x00: 04 FF 40 03 DB 41 01 01 C0 46 03 20 00 56 98 03
          0x10: 42 43 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
          0x20: 32 31 32 31 47 43 46 03 00 81 00 00 00 00 04 00
          0x30: 85 1C 17 EE 04 C4 08 00 00 00 00 00 00 00 00 C5
          0x40: 08 00 00 00 00 00 00 00 00 CB 8E 4E 4D 2D 48 44
          0x50: 56 32 2D 32 54 31 2F 45 31 89 56 30 33 20 D9 02
          0x60: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        FPGA revision:0x16C
        WIC Slot 0:
        FXO Voice daughter card (2 port)
        Hardware revision 1.0           Board revision A0
        Serial number     7048223       Part number    800-02495-01
        FRU Part Number     VIC-2FXO=
        Test history      0x0           RMA number     00-00-00
        Connector type    Wan Module
        EEPROM format version 1
          0x20: 01 0D 01 00 00 6B 8C 1F 50 09 BF 01 00 00 00 00
          0x30: 50 00 00 00 98 01 09 01 FF FF FF FF FF FF FF FF
        WIC Slot 1:
        HDV2 on board t1/e1 controller (2 port)
        PVDM Slot 0:
        32-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
        Hardware Revision        : 4.0
        Part Number              : 73-8539-05
        Board Revision           : B0
        Fab Version              : 04
        PCB Serial Number        : FOC12121JHH
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM2-32
        Version Identifier       : V01
          0x00: 04 FF 40 03 EE 41 04 00 82 49 21 5B 05 42 42 30
          0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 32 31 32
          0x20: 31 4A 48 48 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 88 50 56 44 4D 32 2D 33 32 89 56 30 31 20 D9 02
          0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Router#sho inventory
NAME: "2651XM chassis", DESCR: "2651XM chassis"
, VID: 4.1, SN: FTX0942A2TS
NAME: "High Density Voice2 Network module with on board two port interface ", DESCR: "High Density Voice2 Network module with on board two port interface "
PID: NM-HDV2-2T1/E1    , VID: V03 , SN: FOC12121GCF
NAME: "PVDMII DSP SIMM with Two DSPs", DESCR: "PVDMII DSP SIMM with Two DSPs"
PID: PVDM2-32          , VID: V01 , SN: FOC12121JHH
William Bell
I am fairly certain that the NM-HDV2-2T1/E1 does not support insertion of the VIC-2FXO in the VWIC slot. A bit dated, but you can check this URL:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a008039c333.shtml
HTH.
Bill (@ucguerrilla)
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
William Bell
HTH.
Bill (@ucguerrilla)
