Help, after recovery CUCM 6.1.2-1000-13 some services do not start
  hi, please, after we are restore the  publisher Server with recoevry disc, the server restart and start fine but some services do not start. phone are registered to the server, everithing is fine apparently, but this services is not running, i restart the server 2 times and nothing. (subscriber is fine, failover works correct)
is something that i can do to fix this??
since now thank for help.
A Cisco DB[STARTED]
A Cisco DB Replicator[STARTED]
Cisco AMC Service[STARTED]
Cisco AXL Web Service[STOPPED]  Component is not running
Cisco Bulk Provisioning Service[STARTED]
Cisco CAR Scheduler[STARTED]
Cisco CAR Web Service[STOPPED]  Component is not running
Cisco CDP[STARTED]
Cisco CDP Agent[STARTED]
Cisco CDR Agent[STARTED]
Cisco CDR Repository Manager[STARTED]
Cisco CTIManager[STARTED]
Cisco CTL Provider[STARTED]
Cisco CallManager[STARTED]
Cisco CallManager Admin[STOPPED]  Component is not running
Cisco CallManager Attendant Console Server[STARTED]
Cisco CallManager Cisco IP Phone Services[STOPPED]  Component is not running
Cisco CallManager Personal Directory[STOPPED]  Component is not running
Cisco CallManager SNMP Service[STARTED]
Cisco CallManager Serviceability[STOPPED]  Component is not running
Cisco CallManager Serviceability RTMT[STOPPED]  Component is not running
Cisco Certificate Authority Proxy Function[STARTED]
Cisco Certificate Expiry Monitor[STARTED]
Cisco DHCP Monitor Service[STARTED]
Cisco DRF Local[STARTED]
Cisco DRF Master[STARTED]
Cisco Database Layer Monitor[STARTED]
Cisco Dialed Number Analyzer[STOPPED]  Component is not running
Cisco DirSync[STARTED]
Cisco Extended Functions[STARTED]
Cisco Extension Mobility[STOPPED]  Component is not running
Cisco Extension Mobility Application[STOPPED]  Component is not running
Cisco IP Manager Assistant[STOPPED]  Component is not running
Cisco IP Voice Media Streaming App[STARTED]
Cisco License Manager[STARTED]
Cisco Log Partition Monitoring Tool[STARTED]
Cisco RIS Data Collector[STARTED]
Cisco RTMT Reporter Servlet[STOPPED]  Component is not running
Cisco SOAP - CDRonDemand Service[STARTED]
Cisco Serviceability Reporter[STARTED]
Cisco Syslog Agent[STARTED]
Cisco TAPS Service[STARTED]
Cisco Tftp[STARTED]
Cisco Tomcat[STOPPED]  Component is not running
Cisco Tomcat Stats Servlet[STOPPED]  Component is not running
Cisco Trace Collection Service[STARTED]
Cisco Trace Collection Servlet[STOPPED]  Component is not running
Cisco Unified Mobile Voice Access Service[STOPPED]  Component is not running
Cisco WebDialer Web Service[STOPPED]  Component is not running
Host Resources Agent[STARTED]
MIB2 Agent[STARTED]
Native Agent Adapter[STARTED]
SNMP Master Agent[STARTED]
SOAP -Log Collection APIs[STARTED]
SOAP -Performance Monitoring APIs[STARTED]
SOAP -Real-Time Service APIs[STARTED]
System Application Agent[STARTED]
Cisco Messaging Interface[STOPPED]  Service Not Activated
Red
Re: Help, after recovery CUCM 6.1.2-1000-13 some services do not
You may try to start the service manually.  If it failed to start, you should be able to find the reason in corresponding logs.
Michael
http://htluo.blogspot.com
hi,
it was the firt that i try, buy nothing happend, the service dont start  =(
thank
991
