10-30-2008 07:58 AM - edited 03-15-2019 02:16 PM
Hi all,
At a customer site trying to block incoming calls and am running into issues.
the code is h323 and all calls work fine inbound and out bound.
I applied the following to the router, am i missing something? I want to be able to block certain incoming numbers
voice translation-rule 1
rule 1 reject /9195236831/
rule 2 reject /^9195236831/
voice translation-profile reject
translate calling 1
voice-port 0/0/0:23
translation-profile incoming reject
Solved! Go to Solution.
10-30-2008 09:35 AM
it should be
call-block translation-profile incoming reject
Refer to the documentation for further explanation
Reject Calls
Call Blocking Configuration Examples
java
if this helps, please rate
10-30-2008 09:35 AM
it should be
Reject Calls
java
10-30-2008 11:16 AM
thanks for the info.
I was missing adding the profile to the dial-peer
everywhere i had read before told me to apply to the voice-port. The only way I could get it to work was to add it to the dial peer.
thanks!
