Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Help: CCM service down
My ccm.exe service down in my publisher machine.
I've read Cisco documents where talk about it but I think there is no solution to it.
This documents talk about a lack of resources or a bad version of backup aplication installled in ccm like possible causes to this service down.
I did what this document say with Windows 2000 performance monitor and I see that sqlserv.exe process is using a lot of my CPU resources in the ccm server.
Is there any known bug in ccm about it?.
I use ccm 4.1(3) sr1 and SQL Server 2000 8.00.818 Standard Edition (build 2195: Service Pack 4).
Thanks, Carlos.
Green
Re: Help: CCM service down
Hi Carlos,
"My ccm.exe service down in my publisher machine."
CCM service never started ?
CCM service crashed?
"sqlserv.exe process is using a lot of my CPU resources in the ccm server"
DBLhelper show happy faces?
1. What exact Version of CCM ? Any SR's ? Engg Specials ?
2. What OS ? Could you run STIVER.exe from C:\sti folder or MCSVER.exe from C:\Utils and
upload the outputs ?
3. On which server do you see this SQL CPU ? On the Publisher or the Subscriber ?
Could you check on the following ...
1. Free Disk Space
2. Size of directory C:\Program Files\Microsoft SQL Server\MSSQL\Data
2. Under SQL server Enterprise Manager | select the Server | Management | Current Activity | Process Info.
Which process is consuming CPU usage?
Is there any way you could reboot the server where the CPU is high % ?
If the reboot does not help please enable the following traces and send them off to me
after they are running for about 5 minutes when the CPU starts spiking ...
*** Detailed CCM Traces:[ C:\Program Files\Cisco\Trace\CCM ]
Log in to CCMAdmin > Application > Cisco Call Manager Serviceability > Trace >
Configuration > Select the CCM to which the Devices/GW are registered > Cisco
CallManager. Check the " Trace On " check box. From the Drop Down [ Trace Filter Settings
] for " Debug Trace Level " select Detailed and Update.
*** Detailed SDL\CCM Traces:[ C:\Program Files\Cisco\Trace\SDL\CCM ]
Log in to CCMAdmin > Service > Service Parameters > Select the CCM> Cisco
CallManager. Set SdlTraceFlag to True. Set SdlTraceTypeFlags to 0x8000EB15. Hit Update.
*** Detailed DBL Traces:[ C:\Program Files\Cisco\Trace\DBL ]
Configuration > Select the CCM > Cisco Database Layer Monitor. Check the " Trace On
" check box. From the Drop Down [ Trace Filter Settings ] for " Debug Trace Level " select
Upload the traces with the Application and System Event Viewer Logs in .evt format.
CCM service crash.
I haven't DBLhelper.
I use 4.1(3) sr1 version of CCM.
I had uploaded the MCSServer.exe output.
I saw the SQL CPU in the publisher server.
I have 20.6 GB of free space in hard disk.
The folder Data of SQL Server have 2,52 GB.
I can't see where is the process that are consuming CPU under SQL Server 2000. Can you repeat how I can?. I use SQL Server 2000.
I can't send you trace and event viewer files for security reasons of my company.
Please say me what I must to look and I will say it to you.
Thanks.
Silver
you can also run RTMT to get more Infos.
But i would go for a TAC Case (they will send you DBhelper).
Karzazi
I have RTMT installed.
Can you say what do you want to know?.
Thanks for your answer.
Green
I attached DBLHelper just unzip it paste it to C:\Program Files\Cisco\Bin and run it from there in PUBLISHER.
SQL Enterprise Manager | Microsoft SQL Servers | SQL Server Group | Select the server | Management | Current Activity | Process Info.
I also recommend you to open a TAC case on this one, you will get the service you deserve.
Check out this link:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801d2577.shtml
Thanks for dblhelper program.
I run it and it shows smile faces.
I'd seen the process info in SQL Server and one of them called SQLAgent-Alert Engine is the process that is consuming the more percent of CPU.
I'd already seen this document.
I can't open a TAC case I have no CCO login in cisco.com
I would like that you say me what I must to view in CCM traces I will do it like I said you before.
264
