Community Member
[HELP]Cisco Callmanager 7.0 Busy Trigger script
Hi colleagues ....
There is the possibility of changing the busy trigger setting which by default is 2 for only one? only need to do to all phones, is there any script for this change?
Re: [HELP]Cisco Callmanager 7.0 Busy Trigger script
Yes, using bulk administration.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/7_0_1/t03uplns.html
Hope to help.
Adrian.
Use BAT for such task
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
617
