01-24-2007 09:26 AM - edited 03-14-2019 07:43 PM
Hi all
I have a CCME version 4 in a 2811, I need establish a call code to limit the access to the LD for users.
I know that the CCM have a FAC for this function, but I dont know like does this in CCME.
01-24-2007 01:20 PM
Why don't you try this link:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
Orlando M
01-24-2007 01:52 PM
The limitation with COR configuration as suggested by omendieta, is that no override by PIN is possible.
To have call limitation that can be overridden with a PIN, configure after-hours and login in telephony service, and a PIN for each phone. You can also have a master PIN that remove limitation on all phones.
01-25-2007 11:59 AM
Hi Paolo
I do not have much experience in this, do you know some docuemnto that describes the configuration, and if you have some commentary of as to use it for my case?
01-25-2007 11:48 AM
Hi Orlando
I need establish code for the users, and not by phone.
01-25-2007 12:04 PM
I understand that CCME does not support PIN per user, but only per phone.
The configuration is described in the sysadm guide:
01-25-2007 12:36 PM
Orangel,
well, maybe I didn't understand well at the begining, have u tried this link?
The code you are trying to configure is for outbound call restriction?
01-25-2007 02:12 PM
I have configure COR in the CCME, but I need to establish a code that can give to the user to make salient calls of LD.
is correct, The code I am trying to configure is for outbound call restriction.
Something like FAC (Force Access Code) in CM
01-25-2007 02:29 PM
As I mentioned before, COR blocking does not support PIN override.
There is PIN support on a per-ephone basis, that will allow all the patterns that are denied by the after-hours command.
There is a third method, that is to configure prefixes of like four or five digits, that have to be prepended to the number when calling. You will configure the dial-peer appropriately, and as long these prefixes are know only by the right people, this will allow selective call placement by user. You can also track who uses them and from where, if the appropriate CDR are kept.
01-25-2007 02:43 PM
Yes, as p.bevilacqua replied you need to configure login, after hours, an then the PIN.
Use this links:
Login:
After Hours Block Pattern:
PIN:
Hope it would be useful!
let me know!
