HELP: Gatekeeper admission confirmation (ACF) message missing IP address
GK responding back to our IPIP GWY with ACF message but with IP address of destination remote missing–
value RasMessage ::= admissionConfirm :
      requestSeqNum 39
      bandWidth 160
      callModel direct : NULL
      destCallSignalAddress ipAddress : <MISSING>
>Show gatekeeper endpoints
Showed the site is registered.  Site was pingable.  I rebooted GK.  Waited 20 minutes and saw no site registration into GK but it eventually registered.
Re: HELP: Gatekeeper admission confirmation (ACF) message missin
can u provide following from the GK?
deb h225 asn1
deb gatekeep main 10
sh gatek end
sh gatek zone prefix all
sh gatek gw
sh run
Pl. point to the ACF in ques.
See below for some of the requested info.  We fixed it by rebooting the H323 TERMINAL.  Even though GK showed TERM registered (and pingable), for some reason GK would not respond back with an IP of the TERM in the ACF message.  The GK should've aged out the terminal if it wasn't a valid registration anymore.  Since its working now, I cannot get you a full trace of all the information requested.  The ACF message I posted was the actual message when it failed.  I did not include all of it since it wasn't relevant.
2901-GK-1#sh gatek end
                    GATEKEEPER ENDPOINT REGISTRATION
CallSignalAddr  Port  RASSignalAddr   Port  Zone Name         Type    Flags
172.17.152.129  1720  172.17.152.129  1719  gk-hns            TERM
    E164-ID: 5550304
    E164-ID: 5550305
    H323-ID: HN_Test
192.168.12.177  1720  192.168.12.177  57295 gk-hns            H323-GW
    H323-ID: ipip1@hns
    Voice Capacity Max.=  Avail.=  Current.= 0
Total number of active registrations = 2
No zone prefix are defined.  Its one big zone with intra-zone enabled calls.
2901-GK-1#sh gatek gw
GATEWAY TYPE PREFIX TABLE
Prefix: 1#*    (Default gateway-technology)
  Zone gk-hns master gateway list:
    192.168.12.177:1720 ipip1
Prefix: 2#*
Correct..GK shd have flagged it or forced unregister the terminal
if there was an issue with TTL or Reg refresh.
But ofcourse that didn't happen. If GK was infact seeing it as
registered, it shd have returned proper IP address in the ACF.
So I agree some sort of glitch on the GK. If it happens again,
please do capture info requested.
Also, do u know if the  terminal supports h323 ver v1 or a v2 ?
What do u see for TTL in RRQ ?
249
