HELP:INTEGRATION TO PBX
hello,
the scenario is as described below
the PBX is MARCOTEL with E1 connection from the TELCO.
the connection is as shown below
PBX(with E1 connection)---====-MDF(Main Distriution Frame)------------patch panel--------outlet------phone1
i want to migrate the user to IPT
so the cable from the outlet , which is RJ11 cable to the phone was removed and plugged to an FXO port on a cisco 2801 voice gateway to achieve the connection as shown below
PBX(with E1 connection)---====-MDF(Main Distriution Frame)------------patch panel--------outlet------cisco 2801(voice gateway)-------LAN------callmanager 4.1---cisco ip phone
the phone 1 has a number 2701111
i did a connection plar such that when u call 2701111 it goes to ip phone with extension 190
the issue is after configuring it when u call the number (2701111) it rings but does not ring on the ip phone
i need help on what to do to make this work
Re: HELP:INTEGRATION TO PBX
have u made any dial peer on the gateway
and did u added the gateway in the callmanager
the dial-peer showube like[if u use h323]:
lets say ur callmanager ip address 192.168.1.1
dial-peer voice 1 voip
destination-pattren 190
session target ipv4:192.168.1.1
on the fxo do
voice port [port number]
connection plar opx 190
and u have to have the gateway added in ur callmanger as h323 based on the config above to work and als the ip phon 190 added to the system aswel
good luck
please, if helpful rate
i gateway is fully registered with the call manager as h323
i did connection plar instead of connection plar opx
find attd my gateway config
try to make the fxo like :
voice-port 0/1/0
connection plar-opx 190
ok and let me know if worked or not
149
