Help IP telephony Basics
I want to Implement IP teplephony in my Lab and I have a L2 cisco 2960 POE switch, is it possible that I can create the 2 vlans for voice and data seperately and phones will start registering to the call maanger 9.X ? I will have my call manager on the data vlan and also it will have DHCP server runnign on it.
1 ACCEPTED SOLUTION
Re: Help IP telephony Basics
Hi.
Placing the cucm interface in the Voice Vlan and with a pc with two network interfaces one on Voice Vlan and one on Data Vlan.
Configure a dhcp scope on CUCM within the same CUCM Subnet.
All switch ports will have both data and voice vlan.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Syed.
Sure you can create Data Vlan and Voice Vlan.
On switch port , where you will connect cisco ip phone, you can instruct the phone to tag voice traffic with voice vlan ID through switchport voice vlan command.
Carlo
If the 2 vlans are on the different subnets, will it requiire a router for the phones to regster or with out router using a layer 2 switch I can implement IP TELEPHONY ?
Hi Syed.
Yes you need a router to let 2 vlans with 2 subnets to communicate.
You can also separate Voice Vlan and Data Vlan without route them, but it could be not so easy to manage and not so scalable.
Carlo
Since its a lab I can use seperate Voice and Data Vlans without routing them. Now the question is how its possible.
Hi.
Carlo
186
