Help: ISDN E1 Connection work on voice gateway 3925e but does not work on SRST 3925e
Dear,
I have one VG 3925e and SRST 3925e,
when  i connect the E1 to VG the call can handle normally, but when i use same E1 cable for SRST, the call continue for 4 min and disconnected,
below the debug:
R-VG-1-srst#debug isdn q931
debug isdn q931 isON.
R-VG-1-srst#debug isdn q931  21
debug isdn q921 isON.
R-VG-1-srst#
Apr 23 12:09:15.238: ISDN Se0/0/0:15 Q921: User TX -> RRp sapi=0 tei=0 nr=96
Apr 23 12:09:15.242: ISDN Se0/0/0:15 Q921: User RX <- RRf sapi=0 tei=0 nr=26
Apr 23 12:09:24.842: ISDN Se0/0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=96 nr=26
Apr 23 12:09:24.842: ISDN Se0/0/0:15 Q931: SETUP pd = 8  callref = 0x03FB
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA1838A
Preferred, Channel 10
Progress Ind i = 0x8283 - Origination address is non-ISDN
Calling Party Number i = 0x2183, '662199999'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '1819'
Apr 23 12:09:24.842: ISDN Se0/0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=97
Apr 23 12:09:24.846: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x83FB callID = 0x0021 switch = primary-net5 interface = User
Apr 23 12:09:24.846: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=26 nr=97
Apr 23 12:09:24.846: ISDN Se0/0/0:15 Q931: CALL_PROC pd = 8  callref = 0x83FB
Channel ID i = 0xA9838A
Exclusive, Channel 10
Apr 23 12:09:24.854: ISDN Se0/0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=27
Apr 23 12:09:24.966: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=27 nr=97
Apr 23 12:09:24.966: ISDN Se0/0/0:15 Q931: ALERTING pd = 8  callref = 0x83FB
Apr 23 12:09:24.974: ISDN Se0/0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=28
Apr 23 12:09:26.134: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=28 nr=97
Apr 23 12:09:26.134: ISDN Se0/0/0:15 Q931: CONNECT pd = 8  callref = 0x83FB
Apr 23 12:09:26.142: ISDN Se0/0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=29
Apr 23 12:09:26.190: ISDN Se0/0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=97 nr=29
Apr 23 12:09:26.190: ISDN Se0/0/0:15 Q931: CONNECT_ACK pd = 8  callref = 0x03FB
Apr 23 12:09:26.190: ISDN Se0/0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=98
Apr 23 12:09:26.190: %ISDN-6-CONNECT: Interface Serial0/0/0:9 is now connected to 1819 AR
Apr 23 12:09:31.174: %ISDN-6-DISCONNECT: Interface Serial0/0/0:9  disconnected from 662199999 , call lasted 4 seconds
Apr 23 12:09:31.174: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=29 nr=98
Apr 23 12:09:31.174: ISDN Se0/0/0:15 Q931: DISCONNECT pd = 8  callref = 0x83FB
Cause i = 0x80AF - Resource unavailable, unspecified
Apr 23 12:09:31.182: ISDN Se0/0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=30
Apr 23 12:09:31.194: ISDN Se0/0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=98 nr=30
Apr 23 12:09:31.194: ISDN Se0/0/0:15 Q931: RELEASE pd = 8  callref = 0x03FB
Apr 23 12:09:31.194: ISDN Se0/0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=99
Apr 23 12:09:31.194: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=30 nr=99
Apr 23 12:09:31.194: ISDN Se0/0/0:15 Q931: RELEASE_COMP pd = 8  callref = 0x83FB
Apr 23 12:09:31.202: ISDN Se0/0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=31
Apr 23 12:09:33.034: ISDN Se0/0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=99 nr=31
Apr 23 12:09:33.034: ISDN Se0/0/0:15 Q931: SETUP pd = 8  callref = 0x03FC
Sending Complete
Is that ISDN link up ? Bcoz
Is that ISDN link up ? Bcoz the error you getting is Resource unavailable.
Manish
ISDN Serial0/0/0:15 interface
        dsl 0, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0xFFFF7FFF
    Number of L2 Discards = 0, L2 Session ID = 1
Can you please also show us
Can you please also show us the dial-peers 1 and 100? These are involved in the call.
How is the call coming into the gateway? Is it coming from CUCM ? Which protocol is this?
dial-peer voice 1 pots
 incoming called-number .
 direct-inward-dial
 port 0/0/0:15
dial-peer voice 100 voip
 destination-pattern .T
 session target ipv4:10. x.x.x.x
 incoming called-number 9T
 voice-class h323 1
 dtmf-relay h245-signal h245-alphanumeric
 no vad
:( , any update
:( , any update
Did you get a chance to put
Did you get a chance to put in the codecs in the dial-peers?
how ?
how ?
voice class codec 1 codec
voice class codec 1
codec preference 1 g711ulaw
and assigning this under dp 1 and 100.
voice-class codec 1
only under dp 100, cant under
only under dp 100, cant under dp 1 because pots
and same
VIP Super Bronze
Mustapha, from the logs, the
Mustapha,
from the logs, the call is matching dial-peer 100 in SRST. That doesn't sound right. This call is still routing as though it is normal operation. Can you send your full sh run please.
 voice-class h323 1
 no vad
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
clock timezone gmt 3 0clock
clock calendar-valid
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
network-clock-select 2 E1 0/0/1
network-clock-select 3 E1 0/0/2
network-clock-select 4 E1 0/0/3
no ipv6 cef
no ip source-route
no ip gratuitous-arps
ip cef
no ip bootp server
no ip domain lookup
ip domain name xxxx.com
isdn switch-type primary-net5
voice-card 0
 dsp services dspfarm
voice service voip
 no ip address trusted authenticate
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service h225-notify cid-update
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 h323
  call preserve
voice class codec 1
 codec preference 2 g729r8
voice class h323 1
  h225 timeout tcp establish 3
voice translation-rule 1
 rule 1 /\(.*\)/ /9\1/
voice translation-profile ANI
 translate calling 1
redundancy
controller E1 0/0/0
 framing NO-CRC4
 pri-group timeslots 1-31
controller E1 0/0/1
 framing NO-CRC4
controller E1 0/0/2
 framing NO-CRC4
controller E1 0/0/3
 framing NO-CRC4
interface GigabitEthernet0/0
 ip address 10.10.10.2 255.255.255.252
 duplex auto
 speed auto
 h323-gateway voip interface
 h323-gateway voip bind srcaddr 10.10.10.2
interface Serial0/0/0:15
 no ip address
 encapsulation hdlc
 isdn incoming-voice voice
 no cdp enable
interface Serial0/0/1:15
 no ip address
 encapsulation hdlc
 no cdp enable
interface Serial0/0/2:15
 no ip address
 encapsulation hdlc
 no cdp enable
interface Serial0/0/3:15
 no ip address
 encapsulation hdlc
 no cdp enable
ip default-gateway 10.10.10.1
ip forward-protocol nd
ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.10.10.1
nls resp-timeout 1
cpd cr-id 1
control-plane
voice-port 0/0/0:15
 translation-profile incoming ANI
 bearer-cap Speech
voice-port 0/0/1:15
 bearer-cap Speech
voice-port 0/0/2:15
 --More--          bearer-cap Speech
voice-port 0/0/3:15
 bearer-cap Speech
ccm-manager music-on-hold
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 10.10.10.20 identifier 2 version 7.0
sccp ccm 10.10.10.21 identifier 1 version 7.0
sccp ip precedence 3
sccp
sccp ccm group 1
 bind interface GigabitEthernet0/0
 associate ccm 1 priority 1
 associate ccm 2 priority 2
 associate profile 1 register rizgaryxcoder1
 switchover method immediate
 switchback method immediate
dspfarm profile 1 transcode
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec g729r8
 maximum sessions 12
 associate application SCCP
 direct-inward-dial
 port 0/0/0:15
dial-peer voice 2 pots
 direct-inward-dial
 port 0/0/1:15
dial-peer voice 3 pots
 direct-inward-dial
 port 0/0/2:15
dial-peer voice 4 pots
 direct-inward-dial
 port 0/0/3:15
dial-peer voice 10 pots
 destination-pattern 900T
 prefix 00
dial-peer voice 11 pots
 preference 1
 prefix 00
dial-peer voice 12 pots
 preference 2
 prefix 00
dial-peer voice 13 pots
 preference 3
 prefix 00
dial-peer voice 70 pots
 destination-pattern 90[1-6]T
 prefix 0
dial-peer voice 71 pots
 preference 1
 prefix 0
dial-peer voice 72 pots
 preference 2
 prefix 0
dial-peer voice 73 pots
 preference 3
 prefix 0
 session target ipv4:10.10.10.21
 voice-class codec 1
 voice-class h323 1
 no vad
dial-peer voice 101 voip
 preference 1
 session target ipv4:10.10.10.20
 voice-class codec 1
 voice-class h323 1
 no vad
VIP Super Bronze
This config doesnt show that
This config doesnt show that you have SRST configured. Do your phones work in SRST?
sorry i forgot this!telephony
sorry i forgot this
telephony-service
 srst mode auto-provision all
 srst ephone description CME SRST Fallback : Nov 04 2013 15:58:14 : Apr 10 2014 07:50:02
 srst dn line-mode dual
 max-ephones 100
 max-dn 300 preference 9 no-reg
 ip source-address 10.10.10.2 port 2000
 timeouts interdigit 5
 system message CME SRST
 time-zone 21
 date-format dd-mm-yy
 keepalive 10
 max-conferences 8 gain -6
 call-forward pattern .T
 moh music-on-hold.au
 multicast moh 239.1.1.1 port 16384
 dn-webedit
 time-webedit
 transfer-system full-consult
 transfer-pattern .T
 secondary-dialtone 9
VIP Super Bronze
please reconfigure the ff:
please reconfigure the ff: and test again..
telephony-service
 srst mode auto-provision none (change all to none)
remove the no reg on the max-dn line. the no reg will prevent your phones dn from registering to the gateway
no max-dn 300 preference 9 no-reg
change it to this
I'd suggest creatingvoice
voice class codec 1
voice-class codec 1
What's the protocol you're
What's the protocol you're using on this gateway when it is not in SRST mode?
debug voip ccapi inout should be able to give us the right answer as to where the problem is.
H.323 R-VG-1-srst#debug voip
H.323
R-VG-1-srst#debug voip ccapi inout
Apr 23 14:59:20.158: //-1/89853BE980B5/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=9662199999
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=1819
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Apr 23 14:59:20.158: //-1/89853BE980B5/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x13945F98, Call Info(
   Calling Number=9662199999,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=1819(TON=National, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=1, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Apr 23 14:59:20.158: //-1/89853BE980B5/CCAPI/ccCheckClipClir:
   In: Calling Number=9662199999(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
   Out: Calling Number=9662199999(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
Apr 23 14:59:20.158: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 23 14:59:20.158: :cc_get_feature_vsa malloc success
Apr 23 14:59:20.158:  cc_get_feature_vsa count is 1
Apr 23 14:59:20.158: :FEATURE_VSA attributes are: feature_name:0,feature_time:40152856,feature_id:6176
Apr 23 14:59:20.158: //6176/89853BE980B5/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=9662199999(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=1819(TON=National, NPI=ISDN))
Apr 23 14:59:20.162: //6176/89853BE980B5/CCAPI/cc_process_call_setup_ind:
   Event=0x1390A218
Apr 23 14:59:20.162: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 1819
Apr 23 14:59:20.162: //6176/89853BE980B5/CCAPI/ccCallSetContext:
   Context=0x177E152C
   >>>>CCAPI handed cid 6176 with tag 1 to app "_ManagedAppProcess_Default"
Apr 23 14:59:20.162: //6176/89853BE980B5/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
Apr 23 14:59:20.162: //6176/89853BE980B5/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=100, Params=0x177DEBFC, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Apr 23 14:59:20.162: //6176/89853BE980B5/CCAPI/ccCheckClipClir:
   Destination Pattern=.T, Called Number=1819, Digit Strip=FALSE
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=89853BE9-CA15-11E3-80B5-D0D0FDBFE780, Outgoing Dial-peer=100
Apr 23 14:59:20.162: //6176/89853BE980B5/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=1819
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr 23 14:59:20.162: //6176/89853BE980B5/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x195A3C8, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=9662199999,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=1819(TON=National, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=100, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Apr 23 14:59:20.162: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 23 14:59:20.162: :cc_get_feature_vsa malloc success
Apr 23 14:59:20.162:  cc_get_feature_vsa count is 2
Apr 23 14:59:20.162: :FEATURE_VSA attributes are: feature_name:0,feature_time:40153304,feature_id:6177
Apr 23 14:59:20.162: //6177/89853BE980B5/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Apr 23 14:59:20.162: //6177/89853BE980B5/CCAPI/ccCallSetContext:
   Context=0x177DEBAC
Apr 23 14:59:20.162: //6176/89853BE980B5/CCAPI/ccSaveDialpeerTag:
Apr 23 14:59:20.270: //6177/89853BE980B5/CCAPI/cc_api_set_called_ccm_detected:
   CallInfo(called ccm detected=TRUE ccmVersion 3)
Apr 23 14:59:20.270: //6177/89853BE980B5/CCAPI/cc_api_call_proceeding:
   Interface=0x195A3C8, Progress Indication=NULL(0)
Apr 23 14:59:20.278: //6177/89853BE980B5/CCAPI/cc_api_set_called_ccm_detected:
Apr 23 14:59:20.278: //6177/89853BE980B5/CCAPI/cc_api_set_delay_xport:
   CallInfo(delay xport=TRUE)
Apr 23 14:59:20.278: //6177/89853BE980B5/CCAPI/cc_api_call_alert:
   Interface=0x195A3C8, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
Apr 23 14:59:20.278: //6176/89853BE980B5/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Apr 23 14:59:20.278: //6177/89853BE980B5/CCAPI/cc_api_call_notify:
   Data Bitmask=0x7, Interface=0x195A3C8, Call Id=6177
Apr 23 14:59:20.278: //6177/89853BE980B5/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
   CallInfo(ssCTreRoutingNotSupported=FALSE)
Apr 23 14:59:20.278: //6177/89853BE980B5/CCAPI/cc_api_get_ccm_detected:
   CallInfo(ccm detected=TRUE)
Apr 23 14:59:20.278: //6176/89853BE980B5/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=6176
Apr 23 14:59:24.046: //6177/89853BE980B5/CCAPI/ccIsInfoRingback:
   Returning dpRingBack=0
Apr 23 14:59:24.046: //6177/89853BE980B5/CCAPI/cc_api_call_connected:
   Interface=0x195A3C8, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Apr 23 14:59:24.046: //6177/89853BE980B5/CCAPI/cc_api_set_called_ccm_detected:
Apr 23 14:59:24.046: //6177/89853BE980B5/CCAPI/cc_api_call_notify:
Apr 23 14:59:24.046: //6176/89853BE980B5/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=6176
Apr 23 14:59:24.046: //6176/89853BE980B5/CCAPI/ccConferenceCreate:
   (confID=0x17757168, callID1=0x1820, gcid=89853BE9-CA1511E3-80B5D0D0-FDBFE780, tag=0x0)
Apr 23 14:59:24.046: //6177/89853BE980B5/CCAPI/ccConferenceCreate:
   (confID=0x17757168, callID2=0x1821, gcid=89853BE9-CA1511E3-80B5D0D0-FDBFE780, tag=0x0)
   Conference Id=0x17757168, Call Id1=6176, Call Id2=6177, Tag=0x0
Apr 23 14:59:24.046: //6176/89853BE980B5/CCAPI/cc_api_bridge_done:
   Conference Id=0xFD4, Source Interface=0x13945F98, Source Call Id=6176,
   Destination Call Id=6177, Disposition=0x0, Tag=0xFFFFFFFF
Apr 23 14:59:24.046: //6177/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Apr 23 14:59:24.046: cc_api_get_xcode_stream : 4702
Apr 23 14:59:24.046: //6177/89853BE980B5/CCAPI/cc_api_bridge_done:
   Conference Id=0xFD4, Source Interface=0x195A3C8, Source Call Id=6177,
   Destination Call Id=6176, Disposition=0x0, Tag=0x0
Apr 23 14:59:24.046: //6176/89853BE980B5/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0xFD4, Destination Call Id=6177)
   Call Entry(Conference Id=0xFD4, Destination Call Id=6176)
Apr 23 14:59:24.046: //6176/89853BE980B5/CCAPI/cc_api_caps_ind:
   Destination Interface=0x195A3C8, Destination Call Id=6177, Source Call Id=6176,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Apr 23 14:59:24.046: //6177/89853BE980B5/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Apr 23 14:59:24.046: //6177/89853BE980B5/CCAPI/cc_api_get_ccm_detected:
Apr 23 14:59:24.046: //6176/89853BE980B5/CCAPI/ccCallNotify:
Apr 23 14:59:24.046: //6176/89853BE980B5/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0xFD4, Call Id1=6176, Call Id2=6177
Apr 23 14:59:24.046: //6177/89853BE980B5/CCAPI/cc_api_caps_ind:
   Destination Interface=0x13945F98, Destination Call Id=6176, Source Call Id=6177,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
   Modem=0x0, Codec Bytes=160, Signal Type=2)
Apr 23 14:59:24.046: //6177/89853BE980B5/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1659)
Apr 23 14:59:24.050: //6176/89853BE980B5/CCAPI/cc_api_caps_ack:
Apr 23 14:59:24.050: //6176/89853BE980B5/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
   Call Entry(Connected=TRUE, Responsed=TRUE)
Apr 23 14:59:24.050: //6176/89853BE980B5/CCAPI/cc_api_voice_mode_event:
   Call Id=6176
   Call Entry(Context=0x177E152C)
Apr 23 14:59:24.058: //6177/89853BE980B5/CCAPI/cc_api_caps_ind:
Apr 23 14:59:24.062: //6177/89853BE980B5/CCAPI/cc_api_caps_ind:
Apr 23 14:59:24.062: //6177/89853BE980B5/CCAPI/cc_api_caps_ack:
Apr 23 14:59:24.062: //6176/89853BE980B5/CCAPI/cc_api_caps_ack:
Apr 23 14:59:24.062: //6176/89853BE980B5/CCAPI/cc_api_voice_mode_event:
   Call Id=6176
   Call Id=6176
Apr 23 14:59:24.098: %ISDN-6-CONNECT: Interface Serial0/0/0:9 is now connected to 1819
Apr 23 14:59:29.070: //6177/89853BE980B5/CCAPI/cc_api_call_disconnected:
   Cause Value=47, Interface=0x195A3C8, Call Id=6177
   Call Entry(Responsed=TRUE, Cause Value=47, Retry Count=0)
Apr 23 14:59:29.070: //6176/89853BE980B5/CCAPI/ccConferenceDestroy:
   Conference Id=0xFD4, Tag=0x0
Apr 23 14:59:29.070: //6176/89853BE980B5/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=6177, Disposition=0x0, Tag=0x0
Apr 23 14:59:29.070: //6177/89853BE980B5/CCAPI/cc_api_bridge_drop_done:
Apr 23 14:59:29.070: //6176/89853BE980B5/CCAPI/cc_generic_bridge_done:
Apr 23 14:59:29.074: //6176/89853BE980B5/CCAPI/ccCallDisconnect:
   Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=47, Call Entry(Responsed=TRUE, Cause Value=47)
Apr 23 14:59:29.074: //6176/89853BE980B5/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Apr 23 14:59:29.074: //6177/89853BE980B5/CCAPI/ccCallDisconnect:
   Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=47)
Apr 23 14:59:29.074: //6177/89853BE980B5/CCAPI/cc_api_get_transfer_info:
Apr 23 14:59:29.078: //6177/89853BE980B5/CCAPI/cc_api_get_transfer_info:
Apr 23 14:59:29.078: //6177/89853BE980B5/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x195A3C8, Tag=0x0, Call Id=6177,
   Call Entry(Disconnect Cause=47, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Apr 23 14:59:29.078: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr 23 14:59:29.078: :cc_free_feature_vsa freeing 264B0D0
Apr 23 14:59:29.078:  vsacount in free is 1
Apr 23 14:59:29.090: %ISDN-6-DISCONNECT: Interface Serial0/0/0:9  disconnected from 662199999 , call lasted 4 seconds
Apr 23 14:59:29.110: //6176/89853BE980B5/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x13945F98, Tag=0x0, Call Id=6176,
Apr 23 14:59:29.110: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr 23 14:59:29.110: :cc_free_feature_vsa freeing 264AF10
Apr 23 14:59:29.110:  vsacount in free is 0
530
