Community Member
help need in ldap
hi all,
Having small question , if cucm is synchornized with ldap , if ldap server is not working all the users will come to inactive (perge) state ?
kindly help me on this
thanks in advance
karthik
1 ACCEPTED SOLUTION
help need in ldap
Hi karthik,
Users will not be purged in the scenario you describe. If the LDAP sync fails the users in CUCM will remain active indefinitely.
The only instance in which users will be purged in CUCM is when they are deleted in LDAP and a successful sync takes place.
help need in ldap
Hi karthik,
Community Member
help need in ldap
Thanks for your reply
Karthik
221
