help needed in extension mobility
Hi all,
Is their any process to find which device profiles are using on ip devices ?
Kindly help me
thanks in advance
karthik
1 ACCEPTED SOLUTION
Green
When you look at the DEVICE-->PHONE page
Look at the top right hand side
You will see in a drop down box "ACTIVELY LOGGED IN DEVICE REPORT"
To the right of this click on "GO"
This will give you a new search page
Select the parameter(S) you want to search by to produced an ordered report
E.g.
Drop down and select all user IDs that BEGIN with "A"  click FIND
Just leave blank to find all
What ever suits you.
Alex
Please rate useful posts
Regards, Alex. Please rate useful posts.
which CUCM version
normally you you can find it in the phone settings page, go down in the page you will see in the extension mobilty section loged in profile or user
if the user loged in you will see it
Hi marwanshawi,
thanks for your response
how can we know which end user is using which Device [ extension mobility ] for troubleshooting purpose , is their any way to monitor in bulk
Karthik
Green
E.g.
Alex
149
