help needed in merging location in CUCM
Hi Friends
is there any posibility to merge two location in CUCM?  if so, please let me know how to configure.
Esa
1 REPLY
EXactly what do you mean, you want to take the data from 2 clusters and make it just 1 cluster??
If so, it's either BAT or manually transferring the info.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
190
