Community Member
Help Pls, hardware conference in AS5350XM
I'm on the way migration from 3825 to AS5350XM to increase the media resource requirement. 3825 used transcoder, hardware conference and hardware MTP with CUCM but hardware conference doesn't work in AS5350XM.
Anyone knows why hardware conference doesn't work in AS5350XM
Thanks in advance,
1 ACCEPTED SOLUTION
Re: Help Pls, hardware conference in AS5350XM
The platform you will want to look for larger conference DSP support is the VGD-1T3.
The 6608 is EOS and the CCM module is on it's way out as well. This is the 5xxx CUCM controllable platform with a T3. It will be the first 5xxx platform that can be controlled with MGCP, as well as MTP/conferencing resources.
Here's a link to the relevant configuration:
http://www.cisco.com/en/US/partner/docs/routers/access/vgd1t3/rel1_0/software/configuration/guide/VGD_transcoding.html
It appears that conferencing may not be in support as of now, but it's on the roadmap. I don't know the details of when, but if you have an account / sales team, they would be a good person to ask. Otherwise, I would keep an eye peeled on that link for official conferencing support.
It may work now, but not be in the documentation, it's hard to say. But it's definitely the direction you would want to look.
1 REPLY
120
