08-16-2014 03:58 AM - edited 03-16-2019 11:45 PM
My phones are registered with the CME and i have purchased a Sip trunk . After doing the configuration from my side i am not able to make an outgoing call to the PSTN number through SIP trunk.
I am attaching two files :
1 Router running configuration
2 Debug messages of SIP
Kindly Find the attachment below .
08-16-2014 08:52 AM
Sent: REGISTER sip:gw2.sip.us:5060 SIP/2.0 //// Authorization: Digest username="5245798725",realm="gw2.sip.us",uri="sip:gw2.sip.us:5060",response="7ed5ba1aeac06c817b85c2dbe27367e7",nonce="U+ytflPsqybfv42Ryk9al/95ESy/wYeLXU1gUBM4lrBPyTI8M1DbfH09zxfD",cnonce="D9DAF3A4",qop=auth,algorithm=md5,nc=00000001 Content-Length: 0 Received: SIP/2.0 401 Unauthorized WWW-Authenticate: Digest realm="gw2.sip.us", nonce="U+ytgFPsqygibbsnBlbZSJnSzv9GWaFdXU1gUBM4lrBPyTI8M1DbfFH7dCnA", qop="auth" Content-Length: 0
you sent register and you recieved unauthorized. it looks like username/password incorrect
and dont forget to rate post
08-17-2014 06:43 AM
we had checked several times the username & password with ITSP already.
Thanks for your reply.
08-17-2014 07:34 AM
may be calling or called number incorrect. send debug to provider
08-17-2014 12:48 PM
What is your ITSP saying. You need to work with them to resolve this one..
The invite you sent contains yoru authentication credentials..
Sent:
INVITE sip:912016800906@gw2.sip.us:5060 SIP/2.0
Via: SIP/2.0/UDP 192.235.68.162:5060;branch=z9hG4bK8FBA1C34
Remote-Party-ID: "US-Test" <sip:5245798725@192.235.68.162>;party=calling;screen=no;privacy=off
From: "US-Test" <sip:5245798725@192.235.68.162>;tag=2759C404-12A3
To: <sip:912016800906@gw2.sip.us>
Date: Thu, 14 Aug 2014 13:42:57 GMT
Call-ID: BB4F5769-22EF11E4-8F0FA293-BCD0DDB9@192.235.68.162
Proxy-Authorization: Digest username="5245798725",realm="gw2.sip.us",uri="sip:912016800906@gw2.sip.us:5060",response="5c0780df149e2095ffa2cc3a82324cf1",nonce="U+ytbVPsqxVLlM+Q+FKbz21eW/PJWZ/0qmlfGHm8LYFzoZ5QH6VR0zsOho3C",cnonce="966E3696",qop=auth,algorithm=md5,nc=00000001
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 253
Next they are requesting authorization for using the same credentials you already sent to them
Received:
SIP/2.0 407 Proxy Authentication Required
Via: SIP/2.0/UDP 192.235.68.162:5060;branch=z9hG4bK8FBA1C34;rport=59195
To: <sip:912016800906@gw2.sip.us>;tag=6b55604b003175432ccabd664d6002bd.2cff
CSeq: 102 INVITE
Proxy-Authenticate: Digest realm="gw2.sip.us", nonce="U+ytbVPsqxVY3f1Rcwe6MFkPUG1ZvsHtqmlfGHm8LYFzoZ5QH6VR01H7YxjA", qop="auth"
You need to ask them what is wrong with your authentication credentials..
You also need to verify what realm you need to be using. You have configured gw1.sip.us. But I also see gw2.sip .us..which is which?
Content-Length: 0
