Help to deal with Open SSL/TLS MITM vulnerability (CVE-2014-0224) for BE6K (CUCM 8.6)
Hi all.
End Customer reported this vulnerability: https://www.openssl.org/news/secadv_20140605.txt
I have found this at Cisco http://tools.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-20140605-openssl
How can I know what version of Open SSL I have in Server (It is an MCS7828I5)?
How can I avoid or fix this vulnerability?
Regards.
Jorge
1 ACCEPTED SOLUTION
HW has absolutely nothing to
HW has absolutely nothing to do with this, you need to check your full CUCM version in the bug.
The link you posted has the related bug for each product, and within it, the fixed versions.
java
if this helps, please rate
www.cisco.com/go/pdi
java
Thanks Jaime.I have checked
Thanks Jaime.
I have checked the part of Affected Products >> Vulnerable Products and find the Bug for CUCM.
https://tools.cisco.com/bugsearch/bug/CSCup22670
Best Regards.
123
