Community Member
Help understaning NAT table for SIP
Hi Folks,
I've been battling SIP and NAT for nearly 3 months now   I've got to the point where I think I may well have found a bug in IOS.  Incoming calls are not getting to my CME, outbound calls are fine.  The sip-ua is registered fine.
2611xm-1#show sip-ua register status
Line                              peer        expires(sec)  registered
01xxxxx8882                       -1          86            yes
Without a static route, the NAT translation table on the 877 that connects to the internet looks like this:
877va-1#show ip nat translations
Pro Inside global      Inside local       Outside local      Outside global
udp 82.70.85.118:1024  192.168.1.254:5060 212.23.7.228:5060  212.23.7.228:5060
No incoming calls come through, but looking at the table, I understand why as the ITSP is routing calls to ports 5060, not 1024.
With this static route:
ip nat inside source static udp 192.168.1.254 5060 82.70.85.118 5060 extendable
The table looks like this:
udp 82.70.85.118:5060  192.168.1.254:5060 212.23.7.228:5060  212.23.7.228:5060
udp 82.70.85.118:5060  192.168.1.254:5060 ---                ---
Incoming calls come through, which makes sense as the port is now open!
If I delete the static route, clear the translation table and re-register the sip-ua the table looks like this:
Calls come through for around 12 hours (probably until something times out and the sip-ua re-registers to the first scenario on port 1024).
Why is the 877 setting up the translation to port 1024 - what can I do to fix this?
My 877 settings are:
no ip nat service sip udp port 5060
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 192.168.2.0 255.255.255.0 192.168.1.254
My CME SIP settings are:
sip-ua
credentials username 01xxxxx8882 password xxxxxxxxxxxxxxxxxxx realm voip.zen.co.uk
authentication username 01xxxxx8882 password 7 xxxxxxxxxxxxxxxxxxxxxxxxx
nat symmetric role active
nat symmetric check-media-src
retry invite 3
retry register 10
timers register 150
registrar dns:voip.zen.co.uk expires 120
sip-server dns:voip.zen.co.uk
connection-reuse
  host-registrar
permit hostname dns:voip.zen.co.uk
permit hostname dns:asterisk01.voip.zen.co.uk
permit hostname dns:asterisk02.voip.zen.co.uk
Everyone's tags (2)
I don't think in a bug. Probably when your router uses 1024 port is in PAT.
What is your ios? Are there other translations when 1024 port is used?
Do you have already try to schedule a "clear ip nat trans" ?
Regards.
Community Member
Re: Help understaning NAT table for SIP
Thanks fo thre reply Daniele.
IOS is 15.3(3)M, but I've updated this today from an ealier version hoping to fix the problem.
If I do the following:
877va-1#show ip nat translations | include 5060
udp 82.70.85.118:1029  192.168.1.254:5060 212.23.7.228:5060  212.23.7.228:5060
877va-1#clear ip nat trans
877va-1#clear ip nat translation *
877va-1#clear ip nat statistics
Then on the CME box, re-register the sip-ua.
udp 82.70.85.118:1030  192.168.1.254:5060 212.23.7.228:5060  212.23.7.228:5060
It takes the next port.  Its never using 5060 in the first place from what I can tell
Community Member
I've been trying all afternoon to make some sense of this.  The only way I can get it to NAT 5060->5060 is by putting a static NAT route in, which I believe I shouldn't have to do.
Any help?
665
