HELP - VG224 and outbound faxing
new voice implementation where I setup a VG224 to handle the sites 12 fax machines.  Inbound is working fine but not can fax out bound, keep getting line error issues.  I am able to make calls out from each fax line using analog phone.   The oubound faxes sound like they are connecting but they end up erroring out.  below is router conifg
archive
log config
  hidekeys
interface FastEthernet0/0
ip address XX.XX.XX.XX duplex full
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 XX.XX.XX.XX
ip http server
dialer-list 1 protocol ip permit
snmp-server community ciscoread RO
control-plane
voice-port 2/0
caller-id enable
voice-port 2/1
caller-id enable
voice-port 2/2
caller-id enable
voice-port 2/3
caller-id enable
voice-port 2/4
caller-id enable
voice-port 2/5
caller-id enable
voice-port 2/6
caller-id enable
voice-port 2/7
caller-id enable
voice-port 2/8
caller-id enable
voice-port 2/9
caller-id enable
voice-port 2/10
caller-id enable
voice-port 2/11
caller-id enable
voice-port 2/12
caller-id enable
voice-port 2/13
caller-id enable
voice-port 2/14
caller-id enable
voice-port 2/15
description alarm line
caller-id enable
voice-port 2/16
caller-id enable
voice-port 2/17
caller-id enable
voice-port 2/18
caller-id enable
voice-port 2/19
caller-id enable
voice-port 2/20
caller-id enable
voice-port 2/21
caller-id enable
voice-port 2/22
caller-id enable
voice-port 2/23
caller-id enable
mgcp
sccp local FastEthernet0/0
sccp ccm xx.xx.xx.xx identifier 2
sccp ccm xx.xx.xx.xx identifier 1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
switchback method graceful
dial-peer voice 200 pots
service stcapp
port 2/0
dial-peer voice 201 pots
service stcapp
port 2/1
dial-peer voice 202 pots
service stcapp
port 2/2
dial-peer voice 203 pots
service stcapp
port 2/3
dial-peer voice 204 pots
service stcapp
port 2/4
dial-peer voice 205 pots
service stcapp
port 2/5
dial-peer voice 206 pots
service stcapp
port 2/6
dial-peer voice 207 pots
service stcapp
port 2/7
dial-peer voice 208 pots
service stcapp
port 2/8
dial-peer voice 209 pots
service stcapp
port 2/9
dial-peer voice 210 pots
service stcapp
port 2/10
dial-peer voice 211 pots
service stcapp
port 2/11
dial-peer voice 212 pots
service stcapp
port 2/12
dial-peer voice 213 pots
service stcapp
port 2/13
dial-peer voice 214 pots
service stcapp
port 2/14
dial-peer voice 215 pots
service stcapp
port 2/15
dial-peer voice 216 pots
service stcapp
port 2/16
dial-peer voice 217 pots
service stcapp
port 2/17
dial-peer voice 218 pots
service stcapp
port 2/18
dial-peer voice 219 pots
service stcapp
port 2/19
dial-peer voice 220 pots
service stcapp
port 2/20
dial-peer voice 221 pots
service stcapp
port 2/21
line con 0
line aux 0
line vty 0 4
login local
ntp clock-period 17180026
ntp server xx.xx.xx.xx
end
1 REPLY
Try adding these commands and see if the help, I have many VG224's with fax machine working on them.  It does sometimes take a bit of research to make them work.
I have found the these commands usually help.
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
modem passthrough nse codec g711ulaw
John
394
