HELP. Voice mail is not working
Dfulgencio
I'm having problems with a voicemail.
Scenario:
CME configure with a Unity Express for voice mail. When i call from the PSTN the Auto-Attendat picks up the call,
the call is transfer to an extension.  I let the extension ring until forward the call to the voicemail.
Once i hear the message "leave your message for xxxx", i leave the message but the mailbox doesn't receive any message. The phone doesn't turn on
the light indicating a new message has arrived.  I have configure MWI  on the CME. I also have configure the voice mail in the unity:
CME:
ephone-dn  61
number A61.... no-reg primary
description FOR MWI-ON
mwi on
ephone-dn  62
number A62.... no-reg primary
description FOR MWI-OFF
mwi off
dial-peer voice 5000 voip
description *** FOR VOICE MAIL ****
destination-pattern 5000
session protocol sipv2
session target ipv4:10.234.144.254
dtmf-relay sip-notify rtp-nte
codec g711ulaw
no vad
UNITY VOICEMAIL CONFIG:
voicemail mailbox owner "Rigsanchez" size 5400
description "Rigoberto Sanchez mailbox"
end mailbox
Other thing i noticed is that when i'm leaving the message and press #, for more option,  the system tells me that the message is too short.
Can somebody help me?
Thansk for your response
Can u try adding this while trying g729r8 (default) codec ?
sip-ua
g729-annexb override  <--- add this (hidden so pl. just type)
17 Replies 17
paolo bevilacqua
Is this the same problem you described in another thread? If so, please do not open duplicates.
Not this issue is different.  In the other case when a forwarded the call from the extension to the voicemail, the call didn't connect.
Now i have connection to the voicemail.  But when i leave the message it doesn't leave anything.
I solved the other problem forcing the codec in the incoming dial-peer. I was using a codec list.
thanks..
Does it work when calling from a local ip phone ?
Not.  It doesn't work if i call from an internal phone.
When i'm leaving the message the system tells me that the message is too short, when i selec the # key  for more options. If i close after leaving the message and i check, there is nothing in the mailbox.
I configure the message size to 120 secs the default was 240.  but it  doesn't work with either of them.
thanks...
Is this calling AA, or the phone with VM directly ?
I'am calling from the extension to the VM...
When i make an internal call test.
Its probably one way audio issue CME-->CUE
So nothing gets recorded.
When the call to CUE/VM is up, can u capture:
sh sip call
sh call act voice brief (3 times)
sh voip rtp connect
Also make sure you do not have  ip verify unicast reverse-path  CLI
on any of the interface...there is a known issue with that.
Hi Dilip,
I made the capture. I added to the post.
I'm no too expert in this.  I have little time working with VoIP.
Can you, please, give it a check for me.
Thaks,,
Can u share ur config so that I can make some sense out of
these IP ?
I also see that in the capture there is only one g711 call and
the Tx/Rx count is very low...
It also appears that this was for a call from external and not
from a local IP phone?
Is transcoding in use as there are lots of calls with g729br8
codec; g729br8 has builtin-vad and CUE requires no vad on
the sip dialpeer.
If u can, capture a sniffer off the CUE interface. I can send u
the procedure for using internal packet capture on IOS.
Heres is the config.
The captures you gave are for a call over SIP trunk with xcoding invoked
for g711u<->g729br8
To simplify, can u recreate the issue with on a local IP phone (on vlan 20) and capture those?
Wondering why u r using g729br8 (dialpeer 1100) instead of g729r8 ?
DK
Here is the capture making a call from an internal phone.
The TAC configure this codec I opened a case with them because when the call was transfer from the ext to the VM the VM didn't pick up the call.
Thanks...this looks good...I see Tx counts going up so packets
are being sent to CUE.
Let's see if we can see the same in the sniffer....u can use following
procedure to do a packet capture on the CUE interface.......
First configure following (config t mode)....
ip traffic-export profile DKS mode capture
  bidirectional
  length 512
interface ISM0/0
  ip traffic-export apply DKS size 2000000
Then from enable mode........
pueblo_central#trafffic-export  interface ISM0/0 clear
pueblo_central#trafffic-export  interface ISM0/0 start
---place your test call----
pueblo_central#trafffic-export  interface ISM0/0 stop
pueblo_central#trafffic-export  interface ISM0/0 copy tftp://
Upload CUE.cap
Hi Dilip,
I changed the condec on dial-peer 1100 and it is working.  I put the g711ulaw codec.
How can i make it work using the g729r8 codec?   Because i tried using g729r8 but it didn't work either.
Thanks.
